Until recently, I had the habit, to prepend net names that have active low logic with a ‘/’ character. Yet, the eeschema prohibits the entry of this character. However, older schematics with such net names (e.g. /CS) do not cause any problems. In a dialog box list of net names, these names simply get a double ‘/’. In pcbnew, no problems arises as well.
So my question ist: for what reason can the ‘/’ not be entered as part of the net name?
P.S. The reason for using the ‘/’ character is simple former experience. I believe it was with Orcad: A prepending ‘/’ resulted in a horizontal line over the whole label (in the schematic).
A pin is defined by its graphical representation, its name and its “number”. The pin’s “number” is defined by a set of 4 letters and / or numbers. For the Electrical Rules Check (ERC) tool to be useful, the pin’s “electrical” type (input, output, tri-state…) must also be defined correctly. If this type is not defined properly, the schematic ERC check results may be invalid.
Important notes:
Do not use spaces in pin names and numbers.
To define a pin name with an inverted signal (overline) use the ~ (tilde) character. The next ~ character will turn off the overline. For example ~FO~O would display FO O.
If the pin name is reduced to a single symbol, the pin is regarded as unnamed.
Pin names starting with #, are reserved for power port symbols.
A pin "number" consists of 1 to 4 letters and/ or numbers. 1,2,..9999 are valid numbers. A1, B3, Anod, Gnd, Wire, etc. are also valid.
Duplicate pin "numbers" cannot exist in a symbol.
Everyone has his/her own style when drawing schematics.
For net labelling, I prefer using the style CSEL(L) or WREN(H) just as examples. Advantage is, that they are portable between different packages/programs, as they use standard ASCII characters.
Cool!!!
I just tried it.
Then I checked the docs as well, and indeed I found it, however only under pin assignments of schematic symbols. Shortly after I found out that ‘/’ is no longer accepted, I already looked after the docs…
I’m still curious whether this feature is being present since a long time or not. On office, a computer is equipped with 4.0.7 and an old notebook still carries the latest stable 3.x Windows release…
