Changing the width of already drawn track segments
In legacy canvas mode, I can change the width of an already drawn track, first selecting the new track width from the toolbar then by double clicking the segments I want to change. In opengl canvas mode, double clicking on a track segment opens the property window.
Is there another shortcut or some setting for opengl mode to quickly change tracks width?
In the OpenGL canvas you can select multiple segments with Shift+RightClick, then use the property window (press ‘e’) to change all of their widths at once.
Btw… in legacy canvas mode it’s also easier… just select the track tool, set up the track width you want and then just hover with the mouse over a piece of track that needs changing - hit [E] - done (in case of overlapping tracks under the mouse pointer a selection menu will be offered).
