Changing mouse sensitivity
Hello!
I have found old post about changing mouse sensitivity. The posts are closed because no input for more than 3 months…
One suggestion was to change the sensitivity in the mouse driver. That’s certainly a way to do it, but there are 2 problems:
  • The mouse works fine in all other applications and there is no need to change it. If I do, then the mouse will change also in other applications.
  • Maybe it wouldn’t even work because there is apparently a finite number of zoom factors. What I would appreciate is that the zoom step changes to something smaller. At present it’s something around 20% in my schematic, and if it could be, say, 5% ore even better, adjustable, It would be close to ideal. Is it scheduled in later versions?
    Thanks,
    Pascal
