i’ve created gerber and everything was good but, the GPS that i use in the PCB is not available, so i decided to change it with another one, when I changed the footprint the tracks are still connected with the same pads of the previous footprint, my question is how i update the new connections with the new GPS without remaking the PCB (i’ve changed everything in the Eschema)
i hope that i’m clear, thank you for your answer
Just delete the track segments near the changed connector and re-route new track segments. Easy-peasy.
thank’s for your answer i solved my problem, i just re-generate the netlist and changed the footprint then I re-route the new tracks:)
