Changing colour of tracks/vias as I test them?
I’ve got a old 386 motherboard I’m trying to repair and found all the KiCad files someone has done for the exact board I have (schematics and full PCB layout)
The motherboard as a fair amount of corrosion due to battery damage so I’m busy checking all the tracks and comparing to KiCad. (Doing a continuity test to verify track)
I’m wondering what is the best way to mark my progress and I test them. Is there a way in KiCad to mark individual pads/vias as I verify them as good. Can I change the colour of individual vias/tracks as I test them?
Luckily it’s only a small section of the board but still quite a few tracks/vias to test and I’m starting lose track of what I’ve tested.
I could print out the schematic and mark it with a sharpie but thought there might be a easier to do this on the PCB layout as I’m using this as a guide.
Using KiCad 9.0.0
No, you have to use some workaround.
In v9 you can open the Properties of tracks and choose the technical layer Soldermask. The original purpose of this is to expose the copper, but you can use it as a marker. Vias have the tenting property where Not tented adds soldermask.
Not sure if that’s going to help. I can change the properties to select soldermask but then can’t see this change visually unless I view/edit the properties again.
Found another trick which might work. Edit the properties of track/via and lock it. The colour then changes to blue:
You have to play with layer visibilities. Hide other than, say, front copper and mask. Then change the active layer between those. You can also create a color theme where Mask is 100% opaque and bright. Then you can certainly see the difference between masked/non-masked tracks.
Thanks. The track visibilities slider did the trick. This will work great.
