Change Track Width Globaly and Retrospectively
Hi all,
I have just finished a PCB, and realize I could have had wider tracks.
Is it possible to change all the track to a new width, at once?
In my case there would be no impediment to accommodate them.
I was able to do this when I was using Design Spark years ago…
I simple adjusted the global net entry, and clicked OK.
Thank You.
Francesco C
Pcbnew / Edit / Edit Track & Via Properties
Then experiment a bit with the settings there.
Make sure you have a backup before you start experimenting.
