is there a way to do this ? I have hundreds of lines, I need to change their layers
thanks for your help
There is more information needed, the answer depends on:
Kicad 7.0.5 and I try to change multiple selected line segments layer in the PCB editor
two options:
select lines → Edit (main menu bar) → Edit Text & graphics properties. enable checkboxes for “pcb graphic items” and “Filters: only include selected items”
use properties panel:
1st one works !!
(2nd one does not, there is no properties panel when selecting more than one line)
The properties Manager is a thing you have to enable separately with PCB Editor / View / Show Properties Manager.
