Change in 'pickup width' behaviour?
IIRC the ‘pickup width’ function (or whatever it’s called)
kicad_Sczulrnxxo
picked up the width AND the layer when hovering over a pad/trace and pressing ‘X’ . Now it only picks up the width.
Does anyone known whether that is an intentional change or am I simply delirious?
just checked with Application: KiCad PCB Editor x64 on x64, Version: 7.99.0-2888-g3ee2086f95, release build, Win10, from 22.09.
starting the route-command with “X” respects the layer of the existing track/pad.
But this works only in normal display mode, not in dim/hide display mode.
or I’m simply delirious?
very dangerous question … :slight_smile:
Nope. Refer to video (for the blue track I switch to B.Cu, ‘V’)
Version
Application: KiCad x64 on x64
Version: 7.99.0-2938-g37e8a008ab, release build
	wxWidgets 3.2.2
	FreeType 2.12.1
	HarfBuzz 8.0.0
	FontConfig 2.14.2
	libcurl/8.2.1-DEV Schannel zlib/1.2.13
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
	Date: Sep 26 2023 07:18:34
	wxWidgets: 3.2.2 (wchar_t,wx containers)
	Boost: 1.82.0
	OCC: 7.7.1
	Curl: 8.2.1-DEV
	ngspice: 41
[EDIT] For me it is the same with 2888
Thank you for resisting … :slight_smile:
FWIW: 7.0.7 works as expected.
