Is it possible in kicad to select multiple elements and change the values at the same time? For example, select 5 capacitors and change the value from 1μF to 20μF?
Yes in the PCB Editor using the Properties Manager.
And in the Schematic editor from Version 8
Not sure that meets the OP’s need though . . . for example, select C1, C2 and C9 and change them to 100uF
I interpreted the question as like values to like values, but my interpretations are not always correct.
Either way, between us the OP has options
Thank you very much, that’s exactly what I was looking for.
Is it normal, then, that the ‘Properties…’ window is not available in the multiple selection? Coming from EasyEDA, I found it very convenient to be able to modify the common properties with multiple selection, even those not available in the table you mentioned: different values were displayed with <…>, while those common to all were displayed normally.
It is available in the PCB editor in V7 and will also be available in the Schematic editor from V8. I think I said that already . . .
