Change differential pair dimensions of existing board
I have a fairly large existing and working board that I want to manufacture on a different stackup.
This stackup has defined impedances that are different from the ones it was originally manufactured on.
Is there a way to adjust the differential pairs without manually rerouting the whole board?
I can adjust the net classes of course, but this doesn’t change existing traces.
I produced some prototype boards and they work fine, just… somewhat out of spec I suppose.
Part of me says “if it aint broke don’t fix it”, part of me is slightly uncomfortable with high speed connections being out of spec.
If you update the net class values, it won’t automatically change anything but if you user “Edit->Set Track and Vias Properties” with “Set to net class/ custom rule values” and a combination of filters (By net, net class, layer, etc).
I hope this helps.
