Hi everyone, I am trying to design a capacitive touch sensor previously made for another project. The image attached is how it looks in the application notes and I’m unsure about what material (copper) etc. is used where. Like what would the coupling pad and the touch pad be in kicad? Thanks a lot for your help!
These touch sensors can be made form anything (slightly) conductive. From copper on a PCB to printable carbon containing compound or maybe even a banana.
The design looks dubious though. In general you want to have more open area between the electrodes. This will make the paracitic capacitance smaller, and thus a greater variance when it’s actually sensing anything. Do some research into how to design a proper capacitive sensor.
Also, are you aware that KiCad’s footprint editor has a build in (python) script for generating touch sliders? You can use it, or use it as an example to start from and modify to create your own.
Thanks, sorry for the newbie question. I can’t manage to find this python script for generating touch sliders you speak of. How would one find it? Thanks in advance!
They are Two separate sets of lines. But, they can be used for either Capacitive Touch or Skin-Contact (circuit) closure. Either or Both at same time with different coding.
If you look closely at the Image in the Link I posted, Lower-Left corner shows the Copper covered by a piece of Acrylic Plastic; thus, no Skin-contact closure, Only Capacitance field activates the switch… Different ways to Wire-up things like this… Just need One or more contact points and a GND…
