Is there a way to change the canvas color in Kicad on Linux. ?
The white canvas is blowing out my eyes.
Use sunglasses?
I never understood much about marketing. Apparently âbrightnessâ is a selling point for monitors. I use the normal wite background for any program that comes standard with it and Iâve never had a problem with it. But I do turn the brightness of my monitor down to 14% (I just checked).
The answer you are looking for is more likely to be: ⌠/ Preferences / Preferences / Schematic Editor / Color / Background. But do notice the default color scheme is read-only. You have to create a new color theme before you can change colors.
There are some dark color themes in Plugin & Content Manager.
You may also have dark themes for your OS, depending on your Linux flavor.
I am not going to turn all three monitors down just for Kicad. It is silly and counter productive. Sarcasm is also the lowest form of wit. It achieves nothing.
Thanks,
So it is available in the newest version.
It seems it is not available in the version I am using and my distro do not have a newer version available. Past attempts to install newest version from sources on Debian was not productive so I need to wait till a new version is available in Debian repositories.
Which Version of Kicad do you use in above screenshot?
Will give me an idea which version I should look out for.
If you know which is the first version that included themes let me know.
Thanks for clearing it up.
Problem solved.
You can change the colors in KiCad even if you have a really old version. You just canât install pre-made color themes if your version is from before the plugin and content manager.
FYIâŚ
Some Color Themes are Tweakable and Createable (since from at least several past Kicad versions). Some are âReadâ only⌠explore themâŚ
In Prefâs you can Tweak, Create and Set them (though not all have equivalent panels, options and settings)
Quick Example of changing Schematic BackgroundâŚ
Thanks that helped a lot. Dont know why I did not notice this in the colors settings.
You can also either:
- manually download colour schemes from KiCAD repo and copy them manually to .config directory
- install colour schemes via Plugin and Content Manager (click Colour Themes tab)
Itâs not sarcasm. It was meant quite serious, but with a wink.
Most monitors are still LCDâs with backlight. Having the LED panel produce a lot of light, and then block most of it with the LCD panel is not very energy efficient if you think about it. Therefore I choose regular light themes and just turn down the overall brightness of the display I do have a relatively big monitor (107cm) and it probably uses more energy then the rest of my PC combined (Ryzen 5600G, the fan very rarely gets above itâs slow idle RPM). My new monitor barely gets warm, not nearly as hot as my old 24" HP monitor which still have CLFâs.)
If you have an OLED display, choosing a dark theme makes more sense. Both to reduce energy consumption, and to reduce stress / wear on the display.
I like a dark theme too and I use one called âWitch Hazelâ from the plugin manager.
Hi @retnev
Iâm using the âwDarkâ theme from the Plugins with a much toned down grid on Kicad 8.0.2
The only problem with the kicad themes is they are only for the workspace. See below:
For the surround I use a dark theme from my OS: Linux Mint 21.3 Cinnamon. This Mint has a bucket full of dark themes. See below:
Donât forget, as @paulvdh mentioned way up, you need to save any read only theme as a personal theme before you can modify it.
I donât see that as a problem, but more as a feature.
If KiCad already uses the common GUI theme you set on your PC, then it conforms better with your wishes without even changing any sort of settings yourself.
But I also understand it can be confusing, as settings for themes are now divided between KiCad itself and your OS.
I donât know much about how these themes work (I hardly ever bother to touch such frivolities) but still, would KiCad be able to detect whether you have a âdarkâ or a âlightâ theme on your PC, and then also internally select some default âdarkâ or âlightâ theme? This may be worth a feature request on gitlab.
Not for me. Iâm happy with the current situation.
If I want something changed, Iâd rather do it myself. Kicad may differ from me in its thoughts about what I want. ![]()
This comment was really aimed at the OP who doesnât like a bright screen. As I commented, Kicad themes only half solve the OPâs problem. ![]()
I never understood the reason for white screens. In the early days of CAD, almost all monitors had green traces on a black background. Color hadnât been invented yet, apparently. But Apple and Microsoft apparently thought paper white background was the way to go. The human eye sees by contrast, and any color on a black background is easier to see than on a white screen. But most software started adopting the white background. The color preferences in KiCad made it easy to adopt a black background in all versions I have tried - v4 onward, but I have never tried it on Linux.
Bottom line: Whatever you prefer is best for you. Iâll stick to the black background.
YMMV - Bruce
True,
As an example I used Pcad extensively when it was still on the market eons ago. It is still the nicest clear and contrasted environment on a black background. The newer Cads all have blazing white backgrounds with little contrast and everything is way less visible, fatiguing and annoying as hell.
White background has itâs place (as in real paper no monitor can replicate) , but it is definitely not fit for extended monitor use multi-hour 24/7 work and generally unergonomic for hard working users. Eventually it will get your eyes.
