I deleted an unwanted library from a project specific library,AA-35 power supply. Now when I load the library’s I get Library file “…” not found. OK I read that I need to remove the library from the global table so I go to preferences, manage symbol libraries, and use the remove library from table to remove the library path from the global list. But when I go to close the table I get a “No colon in nicknames” box that says "Illegal character ’ ’ in Nickname: “AA-35 power supply”. The name has a hyphen but no colon and I was allowed to use this name when I built the library.
I assume that I want to delete the path so the library not found error will go away, but the “No colon in nicknames” box keeps popping up. Suggestions?
BTW its KiCad V5.1.4. windows 7
Thanks
Ted
I think error message is misleading and is actually complaining about spaces in the nickname.
