I go to file > print in Pcbnew and nothing is showing up under copper layers or technical layers. How do I print?
That one looks new…
Can you post the version output of KiCAD from the KiCAD main window under Help?
I can confirm this under Ubuntu 16.04 4.1.0 nightly (same build)
Report the bug on launchpad
I raised this as https://bugs.launchpad.net/kicad/+bug/1591530
You can still preview, so can print.
You cannot de-select layers or select extra layers
This is an old problem related to the wxWidgets wxDC and printing on Linux. Use the “Plot” dialog instead.
Bug is raised to CONFIRMED HIGH priority
A fix has been committed on 20/6/16 and nightlies now work properly
