Can't Open Schematic and PCB Editor [KiCad 7.0.0]
Window 11
KiCad 7.0.0 was successfully installed without uninstalling KiCad 6 first, but after that I can’t open any KiCad 6.0.5 project using KiCad 7. KiCad 7 will be force close.
Then I uninstalled KiCad 6, it works - I can use KiCad 7 !
Sorry if this post not informative, I will delete it if needed.
Edit:
I open KiCad 6 file but I don’t know why my design showing like this?
Edit:
When I click B (filled zone) the gap between edge.cuts is loss
Before
After
Successfully rendered on KiCad 7
Design 1
Design 2
Locked items are now shown with this violet shadows. Can be found here:
Had the same in my design.
Check your copper-edge clearance in board setup. KiCad 6 had a bug where this was ignored and the zones kept the copper-copper clearance away from the edge.
