Hi. I have come upon a bizarre artifact that I don’t know how to deal with on my PCB, or how it got there, but it’s in my way, because it’s now bridging multiple neighboring traces.
I can delete everything around the fat purple trace, just not the fat purple trace itself.
I’ve created a project version where I DID delete the entire PCB, leaving only the fat purple trace, and I just don’t know how to modify, fix, or remove it.
You “lock and unlock” with a right click to the “Selection” menu or hotkey L (toggles Lock on and off).
“Bizarre Purple” can be toggled on and off from inside “Objects” in the “Appearance” menu, or the color may be changed to “Subtle Green”, “Delightful Beige” or whatever else you fancy if you wish.
