Can't find an upgrade route to 6.xx
OKAY! That worked beautifully following you guy’s helpful hints.
I do have to finagle new desktop icons/links but everything else worked okay using the instructions in this link, following the TERMINAL instructions not the software manager instructions.
Thanks for the help. I don’t recall any previous instructions via google for upgrading to V6.0 that mentioned having to completely uninstall KiCad but maybe I just missed them. I’m so used to just following ‘Upgrade’ instructions for whatever software I’m using that uninstalling first kinda threw me.
Normally it is not needed to uninstall KiCad, and it should just upgrade.
However, something clearly went haywire on your system, and un-installing KiCad and removing all old repositories is an easy to explain way to advise a cleanup with a reasonable likelihood of “fixing” whatever the underlying problem was.
I SPOKE TOO SOON.
After ‘saving’ a schematic, as per the banner instructions, and reopening, Ver 6 can’t find any Power symbols, or any library parts, it seems to be using the ‘backup’ parts. Even though when I installed, I also installed the new libraries and what not.
So exasperating. Well, something to work on. I suppose it’s only a path problem but why didn’t the coders bother to let us know?
Anyone know where the new LIBS for KiCad are now located in Ver 6? They aren’t in the old folders.
I have them here:
paul@cezanne:/usr/share/kicad/symbols$ ls -hl
total 102M
-rw-r--r-- 1 root root  369K Dec 23 15:25 4xxx_IEEE.kicad_sym
-rw-r--r-- 1 root root  297K Dec 23 15:25 4xxx.kicad_sym
-rw-r--r-- 1 root root  277K Dec 23 15:25 74xGxx.kicad_sym
-rw-r--r-- 1 root root  677K Dec 23 15:25 74xx_IEEE.kicad_sym
-rw-r--r-- 1 root root  941K Dec 23 15:25 74xx.kicad_sym
-rw-r--r-- 1 root root  338K Dec 23 15:25 Amplifier_Audio.kicad_sym
-rw-r--r-- 1 root root   19K Dec 23 15:25 Amplifier_Buffer.kicad_sym
-rw-r--r-- 1 root root  131K Dec 23 15:25 Amplifier_Current.kicad_sym
-rw-r--r-- 1 root root   44K Dec 23 15:25 Amplifier_Difference.kicad_sym
-rw-r--r-- 1 root root   62K Dec 23 15:25 Amplifier_Instrumentation.kicad_sym
-rw-r--r-- 1 root root  550K Dec 23 15:25 Amplifier_Operational.kicad_sym
-rw-r--r-- 1 root root  9,6K Dec 23 15:25 Amplifier_Video.kicad_sym
-rw-r--r-- 1 root root  512K Dec 23 15:25 Analog_ADC.kicad_sym
-rw-r--r-- 1 root root  345K Dec 23 15:25 Analog_DAC.kicad_sym
-rw-r--r-- 1 root root   81K Dec 23 15:25 Analog.kicad_sym
-rw-r--r-- 1 root root  902K Dec 23 15:25 Analog_Switch.kicad_sym
-rw-r--r-- 1 root root  404K Dec 23 15:25 Audio.kicad_sym
-rw-r--r-- 1 root root  358K Dec 23 15:25 Battery_Management.kicad_sym
-rw-r--r-- 1 root root  4,3K Dec 23 15:25 Buffer.kicad_sym
-rw-r--r-- 1 root root  146K Dec 23 15:25 Comparator.kicad_sym
-rw-r--r-- 1 root root  3,7M Dec 23 15:25 Connector_Generic.kicad_sym
-rw-r--r-- 1 root root  3,8M Dec 23 15:25 Connector_Generic_MountingPin.kicad_sym
-rw-r--r-- 1 root root  3,8M Dec 23 15:25 Connector_Generic_Shielded.kicad_sym
-rw-r--r-- 1 root root  3,1M Dec 23 15:25 Connector.kicad_sym
-rw-r--r-- 1 root root  197K Dec 23 15:25 Converter_ACDC.kicad_sym
-rw-r--r-- 1 root root  658K Dec 23 15:25 Converter_DCDC.kicad_sym
-rw-r--r-- 1 root root  616K Dec 23 15:25 CPLD_Altera.kicad_sym
-rw-r--r-- 1 root root   16K Dec 23 15:25 CPLD_Microchip.kicad_sym
-rw-r--r-- 1 root root  221K Dec 23 15:25 CPLD_Xilinx.kicad_sym
-rw-r--r-- 1 root root  247K Dec 23 15:25 CPU.kicad_sym
-rw-r--r-- 1 root root   60K Dec 23 15:25 CPU_NXP_68000.kicad_sym
-rw-r--r-- 1 root root   40K Dec 23 15:25 CPU_NXP_6800.kicad_sym
-rw-r--r-- 1 root root  261K Dec 23 15:25 CPU_NXP_IMX.kicad_sym
-rw-r--r-- 1 root root  193K Dec 23 15:25 CPU_PowerPC.kicad_sym
-rw-r--r-- 1 root root  2,2M Dec 23 15:25 Device.kicad_sym
-rw-r--r-- 1 root root  200K Dec 23 15:25 Diode_Bridge.kicad_sym
-rw-r--r-- 1 root root  620K Dec 23 15:25 Diode.kicad_sym
-rw-r--r-- 1 root root   18K Dec 23 15:25 Diode_Laser.kicad_sym
-rw-r--r-- 1 root root  605K Dec 23 15:25 Display_Character.kicad_sym
-rw-r--r-- 1 root root  144K Dec 23 15:25 Display_Graphic.kicad_sym
-rw-r--r-- 1 root root   46K Dec 23 15:25 Driver_Display.kicad_sym
-rw-r--r-- 1 root root  469K Dec 23 15:25 Driver_FET.kicad_sym
-rw-r--r-- 1 root root  7,2K Dec 23 15:25 Driver_Haptic.kicad_sym
-rw-r--r-- 1 root root  351K Dec 23 15:25 Driver_LED.kicad_sym
-rw-r--r-- 1 root root  291K Dec 23 15:25 Driver_Motor.kicad_sym
-rw-r--r-- 1 root root   23K Dec 23 15:25 Driver_Relay.kicad_sym
-rw-r--r-- 1 root root  7,3K Dec 23 15:25 Driver_TEC.kicad_sym
-rw-r--r-- 1 root root   28K Dec 23 15:25 DSP_AnalogDevices.kicad_sym
-rw-r--r-- 1 root root   41K Dec 23 15:25 DSP_Freescale.kicad_sym
-rw-r--r-- 1 root root  160K Dec 23 15:25 DSP_Microchip_DSPIC33.kicad_sym
-rw-r--r-- 1 root root   38K Dec 23 15:25 DSP_Motorola.kicad_sym
-rw-r--r-- 1 root root   20K Dec 23 15:25 DSP_Texas.kicad_sym
-rw-r--r-- 1 root root  7,2K Dec 23 15:25 Fiber_Optic.kicad_sym
-rw-r--r-- 1 root root   77K Dec 23 15:25 Filter.kicad_sym
-rw-r--r-- 1 root root  560K Dec 23 15:25 FPGA_Lattice.kicad_sym
-rw-r--r-- 1 root root  474K Dec 23 15:25 FPGA_Microsemi.kicad_sym
-rw-r--r-- 1 root root  2,1M Dec 23 15:25 FPGA_Xilinx_Artix7.kicad_sym
-rw-r--r-- 1 root root  948K Dec 23 15:25 FPGA_Xilinx.kicad_sym
-rw-r--r-- 1 root root  2,7M Dec 23 15:25 FPGA_Xilinx_Kintex7.kicad_sym
-rw-r--r-- 1 root root  3,7M Dec 23 15:25 FPGA_Xilinx_Spartan6.kicad_sym
-rw-r--r-- 1 root root  8,0M Dec 23 15:25 FPGA_Xilinx_Virtex5.kicad_sym
-rw-r--r-- 1 root root  6,7M Dec 23 15:25 FPGA_Xilinx_Virtex6.kicad_sym
-rw-r--r-- 1 root root  9,1M Dec 23 15:25 FPGA_Xilinx_Virtex7.kicad_sym
-rw-r--r-- 1 root root   11K Dec 23 15:25 GPU.kicad_sym
-rw-r--r-- 1 root root   79K Dec 23 15:25 Graphic.kicad_sym
-rw-r--r-- 1 root root  229K Dec 23 15:25 Interface_CAN_LIN.kicad_sym
-rw-r--r-- 1 root root  6,8K Dec 23 15:25 Interface_CurrentLoop.kicad_sym
-rw-r--r-- 1 root root  226K Dec 23 15:25 Interface_Ethernet.kicad_sym
-rw-r--r-- 1 root root  274K Dec 23 15:25 Interface_Expansion.kicad_sym
-rw-r--r-- 1 root root   21K Dec 23 15:25 Interface_HDMI.kicad_sym
-rw-r--r-- 1 root root   23K Dec 23 15:25 Interface_HID.kicad_sym
-rw-r--r-- 1 root root  566K Dec 23 15:25 Interface.kicad_sym
-rw-r--r-- 1 root root   55K Dec 23 15:25 Interface_LineDriver.kicad_sym
-rw-r--r-- 1 root root  108K Dec 23 15:25 Interface_Optical.kicad_sym
-rw-r--r-- 1 root root   16K Dec 23 15:25 Interface_Telecom.kicad_sym
-rw-r--r-- 1 root root  475K Dec 23 15:25 Interface_UART.kicad_sym
-rw-r--r-- 1 root root  450K Dec 23 15:25 Interface_USB.kicad_sym
-rw-r--r-- 1 root root   30K Dec 23 15:25 Isolator_Analog.kicad_sym
-rw-r--r-- 1 root root  1,3M Dec 23 15:25 Isolator.kicad_sym
-rw-r--r-- 1 root root   23K Dec 23 15:25 Jumper.kicad_sym
-rw-r--r-- 1 root root  256K Dec 23 15:25 LED.kicad_sym
-rw-r--r-- 1 root root  177K Dec 23 15:25 Logic_LevelTranslator.kicad_sym
-rw-r--r-- 1 root root   30K Dec 23 15:25 Logic_Programmable.kicad_sym
-rw-r--r-- 1 root root   11K Dec 23 15:25 MCU_AnalogDevices.kicad_sym
-rw-r--r-- 1 root root  115K Dec 23 15:25 MCU_Cypress.kicad_sym
-rw-r--r-- 1 root root   18K Dec 23 15:25 MCU_Dialog.kicad_sym
-rw-r--r-- 1 root root  7,2K Dec 23 15:25 MCU_Espressif.kicad_sym
-rw-r--r-- 1 root root  167K Dec 23 15:25 MCU_Intel.kicad_sym
-rw-r--r-- 1 root root   20K Dec 23 15:25 MCU_Microchip_8051.kicad_sym
-rw-r--r-- 1 root root  1,5M Dec 23 15:25 MCU_Microchip_ATmega.kicad_sym
-rw-r--r-- 1 root root  439K Dec 23 15:25 MCU_Microchip_ATtiny.kicad_sym
-rw-r--r-- 1 root root   89K Dec 23 15:25 MCU_Microchip_AVR.kicad_sym
-rw-r--r-- 1 root root   39K Dec 23 15:25 MCU_Microchip_PIC10.kicad_sym
-rw-r--r-- 1 root root  160K Dec 23 15:25 MCU_Microchip_PIC12.kicad_sym
-rw-r--r-- 1 root root  923K Dec 23 15:25 MCU_Microchip_PIC16.kicad_sym
-rw-r--r-- 1 root root  524K Dec 23 15:25 MCU_Microchip_PIC18.kicad_sym
-rw-r--r-- 1 root root   53K Dec 23 15:25 MCU_Microchip_PIC24.kicad_sym
-rw-r--r-- 1 root root  106K Dec 23 15:25 MCU_Microchip_PIC32.kicad_sym
-rw-r--r-- 1 root root   39K Dec 23 15:25 MCU_Microchip_SAMA.kicad_sym
-rw-r--r-- 1 root root  216K Dec 23 15:25 MCU_Microchip_SAMD.kicad_sym
-rw-r--r-- 1 root root  115K Dec 23 15:25 MCU_Microchip_SAME.kicad_sym
-rw-r--r-- 1 root root   73K Dec 23 15:25 MCU_Microchip_SAML.kicad_sym
-rw-r--r-- 1 root root   30K Dec 23 15:25 MCU_Microchip_SAMV.kicad_sym
-rw-r--r-- 1 root root  532K Dec 23 15:25 MCU_Module.kicad_sym
-rw-r--r-- 1 root root   68K Dec 23 15:25 MCU_Nordic.kicad_sym
-rw-r--r-- 1 root root  163K Dec 23 15:25 MCU_NXP_ColdFire.kicad_sym
-rw-r--r-- 1 root root   68K Dec 23 15:25 MCU_NXP_HC11.kicad_sym
-rw-r--r-- 1 root root   37K Dec 23 15:25 MCU_NXP_HC12.kicad_sym
-rw-r--r-- 1 root root   22K Dec 23 15:25 MCU_NXP_HCS12.kicad_sym
-rw-r--r-- 1 root root  890K Dec 23 15:25 MCU_NXP_Kinetis.kicad_sym
-rw-r--r-- 1 root root  226K Dec 23 15:25 MCU_NXP_LPC.kicad_sym
-rw-r--r-- 1 root root   56K Dec 23 15:25 MCU_NXP_MAC7100.kicad_sym
-rw-r--r-- 1 root root   19K Dec 23 15:25 MCU_NXP_MCore.kicad_sym
-rw-r--r-- 1 root root  5,7K Dec 23 15:25 MCU_NXP_NTAG.kicad_sym
-rw-r--r-- 1 root root  527K Dec 23 15:25 MCU_NXP_S08.kicad_sym
-rw-r--r-- 1 root root   28K Dec 23 15:25 MCU_Parallax.kicad_sym
-rw-r--r-- 1 root root   11K Dec 23 15:25 MCU_Renesas_Synergy_S1.kicad_sym
-rw-r--r-- 1 root root  103K Dec 23 15:25 MCU_SiFive.kicad_sym
-rw-r--r-- 1 root root  113K Dec 23 15:25 MCU_SiliconLabs.kicad_sym
-rw-r--r-- 1 root root  9,5K Dec 23 15:25 MCU_STC.kicad_sym
-rw-r--r-- 1 root root  960K Dec 23 15:25 MCU_ST_STM32F0.kicad_sym
-rw-r--r-- 1 root root  954K Dec 23 15:25 MCU_ST_STM32F1.kicad_sym
-rw-r--r-- 1 root root  410K Dec 23 15:25 MCU_ST_STM32F2.kicad_sym
-rw-r--r-- 1 root root  751K Dec 23 15:25 MCU_ST_STM32F3.kicad_sym
-rw-r--r-- 1 root root  2,9M Dec 23 15:25 MCU_ST_STM32F4.kicad_sym
-rw-r--r-- 1 root root  2,4M Dec 23 15:25 MCU_ST_STM32F7.kicad_sym
-rw-r--r-- 1 root root   15K Dec 23 15:25 MCU_ST_STM32G0.kicad_sym
-rw-r--r-- 1 root root  410K Dec 23 15:25 MCU_ST_STM32H7.kicad_sym
-rw-r--r-- 1 root root 1020K Dec 23 15:25 MCU_ST_STM32L0.kicad_sym
-rw-r--r-- 1 root root  1,5M Dec 23 15:25 MCU_ST_STM32L1.kicad_sym
-rw-r--r-- 1 root root  1,4M Dec 23 15:25 MCU_ST_STM32L4.kicad_sym
-rw-r--r-- 1 root root  718K Dec 23 15:25 MCU_ST_STM32L4+.kicad_sym
-rw-r--r-- 1 root root  180K Dec 23 15:25 MCU_ST_STM8.kicad_sym
-rw-r--r-- 1 root root  132K Dec 23 15:25 MCU_Texas.kicad_sym
-rw-r--r-- 1 root root  1,2M Dec 23 15:25 MCU_Texas_MSP430.kicad_sym
-rw-r--r-- 1 root root   11K Dec 23 15:25 MCU_Texas_SimpleLink.kicad_sym
-rw-r--r-- 1 root root   25K Dec 23 15:25 Mechanical.kicad_sym
-rw-r--r-- 1 root root  139K Dec 23 15:25 Memory_EEPROM.kicad_sym
-rw-r--r-- 1 root root   60K Dec 23 15:25 Memory_EPROM.kicad_sym
-rw-r--r-- 1 root root  134K Dec 23 15:25 Memory_Flash.kicad_sym
-rw-r--r-- 1 root root   35K Dec 23 15:25 Memory_NVRAM.kicad_sym
-rw-r--r-- 1 root root  304K Dec 23 15:25 Memory_RAM.kicad_sym
-rw-r--r-- 1 root root   12K Dec 23 15:25 Memory_ROM.kicad_sym
-rw-r--r-- 1 root root  4,1K Dec 23 15:25 Memory_UniqueID.kicad_sym
-rw-r--r-- 1 root root   56K Dec 23 15:25 Motor.kicad_sym
-rw-r--r-- 1 root root  196K Dec 23 15:25 Oscillator.kicad_sym
-rw-r--r-- 1 root root  177K Dec 23 15:25 Potentiometer_Digital.kicad_sym
-rw-r--r-- 1 root root  145K Dec 23 15:25 power.kicad_sym
-rw-r--r-- 1 root root  518K Dec 23 15:25 Power_Management.kicad_sym
-rw-r--r-- 1 root root  343K Dec 23 15:25 Power_Protection.kicad_sym
-rw-r--r-- 1 root root  125K Dec 23 15:25 Power_Supervisor.kicad_sym
-rw-r--r-- 1 root root   33K Dec 23 15:25 pspice.kicad_sym
-rw-r--r-- 1 root root   44K Dec 23 15:25 Reference_Current.kicad_sym
-rw-r--r-- 1 root root  334K Dec 23 15:25 Reference_Voltage.kicad_sym
-rw-r--r-- 1 root root  329K Dec 23 15:25 Regulator_Controller.kicad_sym
-rw-r--r-- 1 root root  2,7K Dec 23 15:25 Regulator_Current.kicad_sym
-rw-r--r-- 1 root root  1,7M Dec 23 15:25 Regulator_Linear.kicad_sym
-rw-r--r-- 1 root root   43K Dec 23 15:25 Regulator_SwitchedCapacitor.kicad_sym
-rw-r--r-- 1 root root  1,7M Dec 23 15:25 Regulator_Switching.kicad_sym
-rw-r--r-- 1 root root  624K Dec 23 15:25 Relay.kicad_sym
-rw-r--r-- 1 root root  231K Dec 23 15:25 Relay_SolidState.kicad_sym
-rw-r--r-- 1 root root   63K Dec 23 15:25 RF_AM_FM.kicad_sym
-rw-r--r-- 1 root root   90K Dec 23 15:25 RF_Amplifier.kicad_sym
-rw-r--r-- 1 root root   80K Dec 23 15:25 RF_Bluetooth.kicad_sym
-rw-r--r-- 1 root root  236K Dec 23 15:25 RF_Filter.kicad_sym
-rw-r--r-- 1 root root   83K Dec 23 15:25 RF_GPS.kicad_sym
-rw-r--r-- 1 root root   91K Dec 23 15:25 RF_GSM.kicad_sym
-rw-r--r-- 1 root root  163K Dec 23 15:25 RF.kicad_sym
-rw-r--r-- 1 root root   30K Dec 23 15:25 RF_Mixer.kicad_sym
-rw-r--r-- 1 root root  252K Dec 23 15:25 RF_Module.kicad_sym
-rw-r--r-- 1 root root  8,6K Dec 23 15:25 RF_NFC.kicad_sym
-rw-r--r-- 1 root root   11K Dec 23 15:25 RF_RFID.kicad_sym
-rw-r--r-- 1 root root  162K Dec 23 15:25 RF_Switch.kicad_sym
-rw-r--r-- 1 root root   15K Dec 23 15:25 RF_WiFi.kicad_sym
-rw-r--r-- 1 root root   36K Dec 23 15:25 RF_ZigBee.kicad_sym
-rw-r--r-- 1 root root  6,8K Dec 23 15:25 Security.kicad_sym
-rw-r--r-- 1 root root  8,5K Dec 23 15:25 Sensor_Audio.kicad_sym
-rw-r--r-- 1 root root  364K Dec 23 15:25 Sensor_Current.kicad_sym
-rw-r--r-- 1 root root  3,3K Dec 23 15:25 Sensor_Distance.kicad_sym
-rw-r--r-- 1 root root   13K Dec 23 15:25 Sensor_Gas.kicad_sym
-rw-r--r-- 1 root root   22K Dec 23 15:25 Sensor_Humidity.kicad_sym
-rw-r--r-- 1 root root   48K Dec 23 15:25 Sensor.kicad_sym
-rw-r--r-- 1 root root   97K Dec 23 15:25 Sensor_Magnetic.kicad_sym
-rw-r--r-- 1 root root   97K Dec 23 15:25 Sensor_Motion.kicad_sym
-rw-r--r-- 1 root root  172K Dec 23 15:25 Sensor_Optical.kicad_sym
-rw-r--r-- 1 root root   30K Dec 23 15:25 Sensor_Pressure.kicad_sym
-rw-r--r-- 1 root root  129K Dec 23 15:25 Sensor_Proximity.kicad_sym
-rw-r--r-- 1 root root  254K Dec 23 15:25 Sensor_Temperature.kicad_sym
-rw-r--r-- 1 root root   89K Dec 23 15:25 Sensor_Touch.kicad_sym
-rw-r--r-- 1 root root  4,6K Dec 23 15:25 Sensor_Voltage.kicad_sym
-rw-r--r-- 1 root root   53K Dec 23 15:25 Simulation_SPICE.kicad_sym
-rw-r--r-- 1 root root  229K Dec 23 15:25 Switch.kicad_sym
-rw-r--r-- 1 root root  130K Dec 23 15:25 Timer.kicad_sym
-rw-r--r-- 1 root root   75K Dec 23 15:25 Timer_PLL.kicad_sym
-rw-r--r-- 1 root root   91K Dec 23 15:25 Timer_RTC.kicad_sym
-rw-r--r-- 1 root root  419K Dec 23 15:25 Transformer.kicad_sym
-rw-r--r-- 1 root root   59K Dec 23 15:25 Transistor_Array.kicad_sym
-rw-r--r-- 1 root root  756K Dec 23 15:25 Transistor_BJT.kicad_sym
-rw-r--r-- 1 root root  817K Dec 23 15:25 Transistor_FET.kicad_sym
-rw-r--r-- 1 root root  8,5K Dec 23 15:25 Transistor_IGBT.kicad_sym
-rw-r--r-- 1 root root   52K Dec 23 15:25 Triac_Thyristor.kicad_sym
-rw-r--r-- 1 root root  117K Dec 23 15:25 Valve.kicad_sym
-rw-r--r-- 1 root root  186K Dec 23 15:25 Video.kicad_sym
Also, note that KiCad does not search for libraries. Upon a first run, it asks you if it should generate the library tables, and if you answer no, then KiCad does not use the libraries even if they are installed.
To fix it, you have to delete the sym-lib-table and fp-lib-table files from your configuration directory. Then KiCad thinks it runs for the first time and re-asks you that question.
More about library management in the FAQ:
https://forum.kicad.info/search?q=library%20management%20category:19
The problem was the choice of timestamp for the version “number” in that testing version of KiCad. It was a bad idea to mix version numbering systems. That version is greater than 6 so cannot be updated by 6. So it had to be deleted. The reason it will/did not get reinstalled is because the repo it came from is already deleted or inactive in /etc/apt/sources.list.d so will not be detected, and 6 can be installed.
Your missing libraries is a known hitch encountered by some and I’m sure people are advising you as I write.
GOOD GRIEF!
I answered YES to the question KiCad asked when I opened the first schematic.
And of course, I don’t even HAVE a ‘symbols’ directory. Not sure I did before I uninstalled either.
Why didn’t the ‘install’ routine add the libraries? I told it to.
That link posted is all about libraries in Ver 5. How would that help converting to Ver 6?
“To fix it, you have to delete the sym-lib-table and fp-lib-table files from your configuration directory. Then KiCad thinks it runs for the first time and re-asks you that question.”
Please explain how to do this? Thanks. What config directory, where is it located? KiCad help doesn’t have a search feature in Ubuntu and I can’t find it.
It was the most common answer for library problems, and I can’t see from here what’s happening on your side.
The instructions were indeed written for KiCad V5, but the way it works is very similar to KiCad V6. File formats have changed, and there is a “Migrate” button, bu the rest is very similar, so those manuals are not obsolete for KiCad V6.
What is your output of:
apt search kicad
There is a possibility you can fix the missing libraries with:
sudo apt install kicad-libraries
The apt search shows a lot of stuff but in a format I am unfamiliar with so I don’t know if it’s showing local folders or what?
Next:
Message after running that apt install — “kicad-libraries set to manually installed.”
I didn’t purposely set it to manually install and didn’t see that as an option anytime I ever tried to upgrade. So okay, I’ll manually install them, but how?
I do not how to say this politely, but keep in mind it’s well meant.
I asked you what the output was of “apt search kicad”, I did not ask you to try to interpret it and tell me you don’t know what it means.
In short: you could read the manual of apt.
A bit longer, it searches for all packages related to KiCad on your system, and the lines that start with a lower case “i” in the first column are the packages that are currently installed.
When you executed
you did set the libraries to be manually installed. That is what that command does. If that was the only message it gave you (so it did not install the libraries themselves) then it means that it did not (have to) install the libraries, and setting it to “manual” was the only thing it did. (This probably means that if you ever uninstall KiCad, then it won’t uninstall those libraries unless you tell your pc to uninstall those to explicitly.
cat ~/.config/kicad/6.0/*-lib-table
“cat” shows the contents of a file (or in this case, of two files. The “sym-lib-table” file and the “fp-lib-table” files and if they are in that location, then those are the files which contain the links to the global libraries.
if those files are empty, then those library tables are not generated properly.
If each of them contains some 100 lines of text, then they do contain the listings of the libraries.
So you do have the libraries installed, (or else you would not have gotten the message “set to manual”) and if those two files are also correct, then the last thing I can think of now is some error in the environment variables ${KICAD6_SYMBOL_DIR} and/or ${KICAD6_FOOTPRINT_DIR}
Also:
I strongly recommend you never copy, paste and execute linux command lines without having an understanding of what they do.
There are all kinds of people out there and there are many different ways to completely wreck your linux installation or data with just a single command.
Okay then…here’s the output:
apt search kicad
Sorting… Done
Full Text Search… Done
horizon-eda/impish,now 1.4.0-1build1 amd64 [installed]
EDA layout and schematic application
kicad/impish,now 6.0.1-1-202201152026+79c1e3a40b~116~ubuntu21.10.1 amd64 [installed]
Electronic schematic and PCB design software
kicad-dbg/impish 6.0.1-1-202201152026+79c1e3a40b~116~ubuntu21.10.1 amd64
Debug symbols for kicad
kicad-demos/impish,impish,now 6.0.1-1-202201152026+79c1e3a40b~116~ubuntu21.10.1 all [installed,automatic]
Common files used by kicad
kicad-doc-ca/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Catalan)
kicad-doc-de/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (German)
kicad-doc-en/impish,impish,now 5.99.0+really5.1.10+dfsg1-1 all [installed,automatic]
Kicad help files (English)
kicad-doc-es/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Spanish)
kicad-doc-fr/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (French)
kicad-doc-id/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Indonesian)
kicad-doc-it/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Italian)
kicad-doc-ja/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Japanese)
kicad-doc-pl/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Polish)
kicad-doc-ru/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Russian)
kicad-doc-zh/impish,impish 5.99.0+really5.1.10+dfsg1-1 all
Kicad help files (Chinese)
kicad-footprints/now 202108051702+da8d1e30c~10~ubuntu20.04.1 all [installed,local]
Kicad footprints (modules)
kicad-libraries/impish,impish,now 6.0.0-1-202112231422+8~ubuntu21.10.1 all [installed]
meta-package for dep to all KiCad libraries (symbols, footprints, templates and 3D models)
kicad-packages3d/impish,impish,now 6.0.0-1-202112231425+e607286d~9~ubuntu21.10.1 all [installed,automatic]
Kicad packages3d (3d models for footprints)
kicad-symbols/now 202108051718+bded9ae0~6~ubuntu20.04.1 all [installed,local]
Kicad symbols (schematic)
kicad-templates/now 202102170017+073d194~8~ubuntu20.04.1 all [installed,local]
Kicad templates
pcb-rnd/impish 2.4.0-1 amd64
Standard installation of pcb-rnd
pcb-rnd-io-alien/impish 2.4.0-1 amd64
File format compatibility with other PCB layout designers.
veroroute/impish 2.06-1 amd64
Veroboard, Perfboard, and PCB layout and routing application
veroroute-data/impish,impish 2.06-1 all
Veroboard, Perfboard, and PCB layout and routing application (data package)
Just had KiCad lock up the computer so tightly, I had to reboot. Wouldn’t even close the main screen when clicking on the X. Better now. Must have been searching for libraries or something.
Everything on my existing schematics look great…even the custom parts…but that’s due to KiCad importing stuff from ‘rescue’ I suspect.
Wow…this is a big screen dump…
Of this: cat ~/.config/kicad/6.0/*-lib-table
jim_hitek@jimhitekHome:~$ cat ~/.config/kicad/6.0/*-lib-table
(fp_lib_table
(lib (name Audio_Module)(type Kicad)(uri ${KICAD6_FOOTPRINT_DIR}/Audio_Module.pretty)(options “”)(descr “Audio Module footprints”))
(lib (name Battery)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Battery.pretty)(options “”)(descr “Battery and battery holder footprints”))
(lib (name Button_Switch_Keyboard)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Button_Switch_Keyboard.pretty)(options “”)(descr “Buttons and switches for keyboard applications”))
(lib (name Button_Switch_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Button_Switch_SMD.pretty)(options “”)(descr “Buttons and switches, surface mount”))
(lib (name Button_Switch_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Button_Switch_THT.pretty)(options “”)(descr “Buttons and switches, through hole”))
(lib (name Buzzer_Beeper)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Buzzer_Beeper.pretty)(options “”)(descr “Audio signalling devices”))
(lib (name Calibration_Scale)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Calibration_Scale.pretty)(options “”)(descr “Scales and grids intended for calibration and measurement”))
(lib (name Capacitor_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Capacitor_SMD.pretty)(options “”)(descr “Capacitor, surface mount”))
(lib (name Capacitor_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Capacitor_THT.pretty)(options “”)(descr “Capacitor, through hole”))
(lib (name Capacitor_Tantalum_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Capacitor_Tantalum_SMD.pretty)(options “”)(descr “Tantalum Capacitor, surface mount”))
(lib (name Connector)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector.pretty)(options “”)(descr “Generic/unsorted connector footprints”))
(lib (name Connector_AMASS)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_AMASS.pretty)(options “”)(descr “AMASS connector footprints”))
(lib (name Connector_Amphenol)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Amphenol.pretty)(options “”)(descr “Amphenol LTW connector footprints”))
(lib (name Connector_Audio)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Audio.pretty)(options “”)(descr “Audio connector footprints”))
(lib (name Connector_BarrelJack)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_BarrelJack.pretty)(options “”)(descr “(DC) barrel jack connector footprints”))
(lib (name Connector_Card)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Card.pretty)(options “”)(descr “Card and card holder footprints”))
(lib (name Connector_Coaxial)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Coaxial.pretty)(options “”)(descr “Coaxial and RF connector footprints”))
(lib (name Connector_DIN)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_DIN.pretty)(options “”)(descr “DIN connector footprints”))
(lib (name Connector_Dsub)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Dsub.pretty)(options “”)(descr “DSub connector footprints”))
(lib (name Connector_FFC-FPC)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_FFC-FPC.pretty)(options “”)(descr “FFC (Flexible Flat Cable) and FPC (Flexible Printed Circuit) connector footprints”))
(lib (name Connector_HDMI)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_HDMI.pretty)(options “”)(descr “HDMI connector footprints”))
(lib (name Connector_Harwin)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Harwin.pretty)(options “”)(descr “Harwin connector footprints”))
(lib (name Connector_Hirose)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Hirose.pretty)(options “”)(descr “Hirose connector footprints”))
(lib (name Connector_IDC)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_IDC.pretty)(options “”)(descr “IDC connector footprints”))
(lib (name Connector_JAE)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_JAE.pretty)(options “”)(descr “JAE connector footprints”))
(lib (name Connector_JST)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_JST.pretty)(options “”)(descr “JST connector footprints www.jst.com”))
(lib (name Connector_Molex)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Molex.pretty)(options “”)(descr “Molex connector footprints www.molex.com”))
(lib (name Connector_Multicomp)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Multicomp.pretty)(options “”)(descr “Multicomp connector footprints”))
(lib (name Connector_PCBEdge)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PCBEdge.pretty)(options “”)(descr “PCB edge connectors (e.g. PCI, ISA, PCIe, …)”))
(lib (name Connector_Pin)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Pin.pretty)(options “”)(descr “Single (solder) pin conectors”))
(lib (name Connector_PinHeader_1.00mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinHeader_1.00mm.pretty)(options “”)(descr “Pin headers, 1.0mm pitch”))
(lib (name Connector_PinHeader_1.27mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinHeader_1.27mm.pretty)(options “”)(descr “Pin headers, 1.27mm pitch”))
(lib (name Connector_PinHeader_2.00mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinHeader_2.00mm.pretty)(options “”)(descr “Pin headers, 2.0mm pitch”))
(lib (name Connector_PinHeader_2.54mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinHeader_2.54mm.pretty)(options “”)(descr “Pin headers, 2.54mm pitch”))
(lib (name Connector_PinSocket_1.00mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinSocket_1.00mm.pretty)(options “”)(descr “Pin sockets, 1.00mm pitch”))
(lib (name Connector_PinSocket_1.27mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinSocket_1.27mm.pretty)(options “”)(descr “Pin sockets, 1.27mm pitch”))
(lib (name Connector_PinSocket_2.00mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinSocket_2.00mm.pretty)(options “”)(descr “Pin sockets, 2.0mm pitch”))
(lib (name Connector_PinSocket_2.54mm)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_PinSocket_2.54mm.pretty)(options “”)(descr “Pin sockets, 2.54mm pitch”))
(lib (name Connector_Phoenix_MC)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Phoenix_MC.pretty)(options “”)(descr “Phoenix MC connector footprints”))
(lib (name Connector_Phoenix_MC_HighVoltage)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Phoenix_MC_HighVoltage.pretty)(options “”)(descr “Phoenix high voltage (320V, 5.08mm pitch) MC connector footprints”))
(lib (name Connector_Phoenix_MSTB)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Phoenix_MSTB.pretty)(options “”)(descr “Phoenix MSTB connector footprints”))
(lib (name Connector_Phoenix_GMSTB)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Phoenix_GMSTB.pretty)(options “”)(descr “Phoenix GMSTB series (high voltage MSTB) connector footprints”))
(lib (name Connector_Samtec)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Samtec.pretty)(options “”)(descr “Samtec connector footprints”))
(lib (name Connector_Samtec_HLE_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Samtec_HLE_SMD.pretty)(options “”)(descr “Samtec surface mount HLE series connector footprints”))
(lib (name Connector_Samtec_HLE_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Samtec_HLE_THT.pretty)(options “”)(descr “Samtec through hole HLE series connector footprints”))
(lib (name Connector_RJ)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_RJ.pretty)(options “”)(descr “Registered Jack (RJ) connector footprints (e.g. RJ11, RJ45, …)”))
(lib (name Connector_SATA_SAS)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_SATA_SAS.pretty)(options “”)(descr “SATA/SAS connector footprints”))
(lib (name Connector_Stocko)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Stocko.pretty)(options “”)(descr “Stocko connector footprints”))
(lib (name Connector_TE-Connectivity)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_TE-Connectivity.pretty)(options “”)(descr “Footprints for connectors by TE Connectivity”))
(lib (name Connector_USB)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_USB.pretty)(options “”)(descr “USB connector footprints”))
(lib (name Connector_Wago)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Wago.pretty)(options “”)(descr “Wago connector footprints”))
(lib (name Connector_Wire)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Wire.pretty)(options “”)(descr “Footprints for solder wire pads”))
(lib (name Connector_Wuerth)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Connector_Wuerth.pretty)(options “”)(descr “Wuerth connector footprints”))
(lib (name Converter_ACDC)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Converter_ACDC.pretty)(options “”)(descr “AC/DC converter footprints”))
(lib (name Converter_DCDC)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Converter_DCDC.pretty)(options “”)(descr “DC/DC converter footprints”))
(lib (name Crystal)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Crystal.pretty)(options “”)(descr “Crystal footprints”))
(lib (name Diode_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Diode_SMD.pretty)(options “”)(descr “Diode footprints, surface mount”))
(lib (name Diode_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Diode_THT.pretty)(options “”)(descr “Diode footprints, through hole”))
(lib (name Display_7Segment)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Display_7Segment.pretty)(options “”)(descr “Seven segment Display”))
(lib (name Display)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Display.pretty)(options “”)(descr “Display modules”))
(lib (name Ferrite_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Ferrite_THT.pretty)(options “”)(descr “Ferrite bead, through hole”))
(lib (name Fiducial)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Fiducial.pretty)(options “”)(descr “Fiducial markings”))
(lib (name Filter)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Filter.pretty)(options “”)(descr “Filter footprints”))
(lib (name Fuse)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Fuse.pretty)(options “”)(descr “Fuse and fuse holder footprints”))
(lib (name Heatsink)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Heatsink.pretty)(options “”)(descr “Heatsinks and thermal products”))
(lib (name Inductor_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Inductor_SMD.pretty)(options “”)(descr “Inductor footprints, surface mount”))
(lib (name Inductor_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Inductor_THT.pretty)(options “”)(descr “Inductor footprints, through hole”))
(lib (name Jumper)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Jumper.pretty)(options “”)(descr “Jumpers, solder jumpers, … footprints”))
(lib (name LED_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/LED_SMD.pretty)(options “”)(descr “Light emitting diodes (LED), surface mount”))
(lib (name LED_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/LED_THT.pretty)(options “”)(descr “Light emitting diodes (LED), through hole”))
(lib (name Module)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Module.pretty)(options “”)(descr “Footprints for SoM (System on Module)”))
(lib (name MountingHole)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/MountingHole.pretty)(options “”)(descr “Mechanical fasteners”))
(lib (name Mounting_Wuerth)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Mounting_Wuerth.pretty)(options “”)(descr “Mechanical fasteners by wuerth electronics”))
(lib (name MountingEquipment)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/MountingEquipment.pretty)(options “”)(descr “Mechanical parts”))
(lib (name NetTie)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/NetTie.pretty)(options “”)(descr “Net ties”))
(lib (name OptoDevice)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/OptoDevice.pretty)(options “”)(descr “Optical devices (light sensors, opto isolators/interrupters, laser diodes, fiber optical components, lightpipes, lenses …)”))
(lib (name Oscillator)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Oscillator.pretty)(options “”)(descr “Footprints for oscillator devices”))
(lib (name Package_BGA)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_BGA.pretty)(options “”)(descr “Ball Grid Array (BGA)”))
(lib (name Package_CSP)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_CSP.pretty)(options “”)(descr “Chip Scale Packages (CSP)”))
(lib (name Package_DFN_QFN)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_DFN_QFN.pretty)(options “”)(descr “Surface mount IC packages, DFN / LGA / QFN”))
(lib (name Package_DIP)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_DIP.pretty)(options “”)(descr “Through hole IC packages, DIP”))
(lib (name Package_DirectFET)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_DirectFET.pretty)(options “”)(descr “DirectFET packages from International Rectifier”))
(lib (name Package_LCC)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_LCC.pretty)(options “”)(descr “Leaded Chip Carriers (LCC)”))
(lib (name Package_LGA)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_LGA.pretty)(options “”)(descr “Land Grid Array (LGA)”))
(lib (name Package_QFP)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_QFP.pretty)(options “”)(descr “Quad Flat Package (QFP)”))
(lib (name Package_SIP)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_SIP.pretty)(options “”)(descr “Single Inline Package(SIP)”))
(lib (name Package_SO)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_SO.pretty)(options “”)(descr “Small Outline Integrated Circuits (SOIC, SSOP, xSOP, xSO)”))
(lib (name Package_SO_J-Lead)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_SO_J-Lead.pretty)(options “”)(descr “Small Outline Integrated Circuits J-Lead”))
(lib (name Package_SON)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_SON.pretty)(options “”)(descr “Small Outline No-Lead (SON)”))
(lib (name Package_TO_SOT_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_TO_SOT_SMD.pretty)(options “”)(descr “Surface mount transistor packages”))
(lib (name Package_TO_SOT_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Package_TO_SOT_THT.pretty)(options “”)(descr “Through hole transistor packages”))
(lib (name Potentiometer_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Potentiometer_SMD.pretty)(options “”)(descr “Potentiometer footprints, surface mount (SMD)”))
(lib (name Potentiometer_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Potentiometer_THT.pretty)(options “”)(descr “Potentiometer footprints, through hole (THT)”))
(lib (name Relay_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Relay_SMD.pretty)(options “”)(descr “Surface mount relay packages”))
(lib (name Relay_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Relay_THT.pretty)(options “”)(descr “Through hole relay packages”))
(lib (name Resistor_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Resistor_SMD.pretty)(options “”)(descr “Resistor footprints, surface mount (SMD)”))
(lib (name Resistor_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Resistor_THT.pretty)(options “”)(descr “Resistor footprints, through hole (THT)”))
(lib (name RF)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF.pretty)(options “”)(descr “Specialized footprints for RF components that don’t fit in the other RF libraries.”))
(lib (name RF_Antenna)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_Antenna.pretty)(options “”)(descr “Radio-frequency / wireless antenna footprints”))
(lib (name RF_Converter)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_Converter.pretty)(options “”)(descr “Specialized footprints for RF signal converters (Like Attenuators, Baluns, Mixers, Couplers, etc.)”))
(lib (name RF_GPS)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_GPS.pretty)(options “”)(descr “GNSS footprints”))
(lib (name RF_GSM)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_GSM.pretty)(options “”)(descr “GSM Modules footprints”))
(lib (name RF_Mini-Circuits)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_Mini-Circuits.pretty)(options “”)(descr “Footprints for Mini-Circuits RF parts.”))
(lib (name RF_Module)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_Module.pretty)(options “”)(descr “Radio-frequency / wireless modules”))
(lib (name RF_WiFi)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_WiFi.pretty)(options “”)(descr “WiFi modules”))
(lib (name RF_Shielding)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/RF_Shielding.pretty)(options “”)(descr “Specialied footprints for EMI shields and covers”))
(lib (name Rotary_Encoder)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Rotary_Encoder.pretty)(options “”)(descr “Rotary Encoder Footprints”))
(lib (name Sensor)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor.pretty)(options “”)(descr “Specialized footprints for multi-function sensors”))
(lib (name Sensor_Audio)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Audio.pretty)(options “”)(descr “Specialized footprints for audio sensors”))
(lib (name Sensor_Distance)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Distance.pretty)(options “”)(descr “Specialized footprints for distance sensors”))
(lib (name Sensor_Current)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Current.pretty)(options “”)(descr “Specialized footprints for current sensors”))
(lib (name Sensor_Humidity)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Humidity.pretty)(options “”)(descr “Specialized footprints for humidity sensors”))
(lib (name Sensor_Motion)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Motion.pretty)(options “”)(descr “Specialized footprints for motion sensors”))
(lib (name Sensor_Pressure)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Pressure.pretty)(options “”)(descr “Specialized footprints for pressure sensors”))
(lib (name Sensor_Voltage)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Sensor_Voltage.pretty)(options “”)(descr “Specialized footprints for voltage sensors”))
(lib (name Socket)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Socket.pretty)(options “”)(descr “Sockets”))
(lib (name Symbol)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Symbol.pretty)(options “”)(descr “PCB symbols”))
(lib (name TerminalBlock_Altech)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_Altech.pretty)(options “”)(descr “Altech terminal block footprints”))
(lib (name TerminalBlock)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock.pretty)(options “”)(descr “Footprints for terminal blocks that do not have their own manufacturer specific library.”))
(lib (name TerminalBlock_4Ucon)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_4Ucon.pretty)(options “”)(descr “4UCON terminal blocks”))
(lib (name TerminalBlock_Dinkle)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_Dinkle.pretty)(options “”)(descr “Dinkle terminal blocks”))
(lib (name TerminalBlock_MetzConnect)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_MetzConnect.pretty)(options “”)(descr “Metz Connect terminal blocks”))
(lib (name TerminalBlock_Philmore)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_Philmore.pretty)(options “”)(descr “Philmore terminal blocks”))
(lib (name TerminalBlock_Phoenix)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_Phoenix.pretty)(options “”)(descr “Phoenix Contact terminal blocks”))
(lib (name TerminalBlock_RND)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_RND.pretty)(options “”)(descr “RND terminal blocks”))
(lib (name TerminalBlock_TE-Connectivity)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_TE-Connectivity.pretty)(options “”)(descr “TE Connectivity terminal blocks”))
(lib (name TerminalBlock_WAGO)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_WAGO.pretty)(options “”)(descr “WAGO terminal blocks”))
(lib (name TerminalBlock_Wuerth)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TerminalBlock_Wuerth.pretty)(options “”)(descr “Wuerth Elektronik terminal blocks”))
(lib (name TestPoint)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/TestPoint.pretty)(options “”)(descr “Test points, measurement points, probe connection points”))
(lib (name Transformer_SMD)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Transformer_SMD.pretty)(options “”)(descr “Surface mount transformers”))
(lib (name Transformer_THT)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Transformer_THT.pretty)(options “”)(descr “Through hole transformers”))
(lib (name Valve)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Valve.pretty)(options “”)(descr “Valve”))
(lib (name Varistor)(type KiCad)(uri ${KICAD6_FOOTPRINT_DIR}/Varistor.pretty)(options “”)(descr “Varistor”))
(sym_lib_table
(lib (name “4xxx”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/4xxx.kicad_sym”)(options “”)(descr “4xxx series symbols”))
(lib (name “4xxx_IEEE”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/4xxx_IEEE.kicad_sym”)(options “”)(descr “4xxx series IEEE symbols”))
(lib (name “74xGxx”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/74xGxx.kicad_sym”)(options “”)(descr “74xGxx symbols”))
(lib (name “74xx”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/74xx.kicad_sym”)(options “”)(descr “74xx symbols”))
(lib (name “74xx_IEEE”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/74xx_IEEE.kicad_sym”)(options “”)(descr “74xx series IEEE symbols”))
(lib (name “Amplifier_Audio”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Audio.kicad_sym”)(options “”)(descr “Amplifier for audio applications”))
(lib (name “Amplifier_Buffer”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Buffer.kicad_sym”)(options “”)(descr “Buffer amplifiers”))
(lib (name “Amplifier_Current”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Current.kicad_sym”)(options “”)(descr “Amplifiers for current sensors (shunt)”))
(lib (name “Amplifier_Difference”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Difference.kicad_sym”)(options “”)(descr “Amplifiers for analog differential signals”))
(lib (name “Amplifier_Operational”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Operational.kicad_sym”)(options “”)(descr “General operational amplifiers”))
(lib (name “Amplifier_Instrumentation”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Instrumentation.kicad_sym”)(options “”)(descr “Instrumentation amplitifers”))
(lib (name “Amplifier_Video”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Amplifier_Video.kicad_sym”)(options “”)(descr “Video amplifiers”))
(lib (name “Analog”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Analog.kicad_sym”)(options “”)(descr “Miscellaneous analog devices”))
(lib (name “Analog_ADC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Analog_ADC.kicad_sym”)(options “”)(descr “Analog to digital converters”))
(lib (name “Analog_DAC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Analog_DAC.kicad_sym”)(options “”)(descr “Digital to analog converters”))
(lib (name “Analog_Switch”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Analog_Switch.kicad_sym”)(options “”)(descr “Analog switches”))
(lib (name “Audio”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Audio.kicad_sym”)(options “”)(descr “Audio devices”))
(lib (name “Battery_Management”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Battery_Management.kicad_sym”)(options “”)(descr “Battery management ICs”))
(lib (name “Buffer”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Buffer.kicad_sym”)(options “”)(descr “High-speed clock/data buffer ICs”))
(lib (name “Comparator”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Comparator.kicad_sym”)(options “”)(descr “Comparator symbols”))
(lib (name “Connector”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Connector.kicad_sym”)(options “”)(descr “Connector symbols (Examples: Terminal Block, D-SUB, DIN, USB…)”))
(lib (name “Connector_Generic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Connector_Generic.kicad_sym”)(options “”)(descr “Generic connector symbols”))
(lib (name “Connector_Generic_MountingPin”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Connector_Generic_MountingPin.kicad_sym”)(options “”)(descr “Generic connectors with mechanical mounting pin”))
(lib (name “Connector_Generic_Shielded”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Connector_Generic_Shielded.kicad_sym”)(options “”)(descr “Generic shielded connector symbols”))
(lib (name “Converter_ACDC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Converter_ACDC.kicad_sym”)(options “”)(descr “AC to DC converter modules”))
(lib (name “Converter_DCDC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Converter_DCDC.kicad_sym”)(options “”)(descr “DC to DC converter modules”))
(lib (name “CPLD_Altera”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPLD_Altera.kicad_sym”)(options “”)(descr “Altera CPLD symbols”))
(lib (name “CPLD_Microchip”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPLD_Microchip.kicad_sym”)(options “”)(descr “Microchip CPLD symbols”))
(lib (name “CPLD_Xilinx”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPLD_Xilinx.kicad_sym”)(options “”)(descr “Xilinx CPLD symbols”))
(lib (name “CPU”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPU.kicad_sym”)(options “”)(descr “Central processor unit (CPU) symbols, assorted”))
(lib (name “CPU_NXP_6800”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPU_NXP_6800.kicad_sym”)(options “”)(descr “NXP (formerly Motorola) 6800 CPUs”))
(lib (name “CPU_NXP_68000”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPU_NXP_68000.kicad_sym”)(options “”)(descr “NXP (formerly Motorola) 68000 CPUs”))
(lib (name “CPU_NXP_IMX”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPU_NXP_IMX.kicad_sym”)(options “”)(descr “NXP IMX CPUs”))
(lib (name “CPU_PowerPC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/CPU_PowerPC.kicad_sym”)(options “”)(descr “PowerPC-based CPUs”))
(lib (name “Device”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Device.kicad_sym”)(options “”)(descr “Generic symbols for common devices”))
(lib (name “Diode”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Diode.kicad_sym”)(options “”)(descr “Diodes”))
(lib (name “Diode_Bridge”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Diode_Bridge.kicad_sym”)(options “”)(descr “Diode Bridges/Rectifiers”))
(lib (name “Diode_Laser”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Diode_Laser.kicad_sym”)(options “”)(descr “Laser diodes”))
(lib (name “Display_Character”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Display_Character.kicad_sym”)(options “”)(descr “Character displays. (n-Segment, dot-matrix, …)”))
(lib (name “Display_Graphic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Display_Graphic.kicad_sym”)(options “”)(descr “Graphic displays. (Pixel-based color or monochrome displays.)”))
(lib (name “Driver_Display”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_Display.kicad_sym”)(options “”)(descr “Drivers for displays. (For graphic and character based displays.)”))
(lib (name “Driver_FET”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_FET.kicad_sym”)(options “”)(descr “MOSFET and gate drivers”))
(lib (name “Driver_Haptic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_Haptic.kicad_sym”)(options “”)(descr “Haptic drivers for solenoids, voice coils, LRAs, etc.”))
(lib (name “Driver_LED”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_LED.kicad_sym”)(options “”)(descr “LED drivers”))
(lib (name “Driver_Motor”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_Motor.kicad_sym”)(options “”)(descr “Integrated motor driver and controller ICs”))
(lib (name “Driver_Relay”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_Relay.kicad_sym”)(options “”)(descr “Relay drivers and controllers”))
(lib (name “Driver_TEC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Driver_TEC.kicad_sym”)(options “”)(descr “Thermoelectric cooler (Peltier) drivers and controllers”))
(lib (name “DSP_AnalogDevices”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/DSP_AnalogDevices.kicad_sym”)(options “”)(descr “Analog Devices DSP symbols”))
(lib (name “DSP_Freescale”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/DSP_Freescale.kicad_sym”)(options “”)(descr “Freescale DSP symbols”))
(lib (name “DSP_Microchip_DSPIC33”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/DSP_Microchip_DSPIC33.kicad_sym”)(options “”)(descr “Microchip DSPIC33 symbols”))
(lib (name “DSP_Motorola”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/DSP_Motorola.kicad_sym”)(options “”)(descr “Motorola DSP symbols”))
(lib (name “DSP_Texas”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/DSP_Texas.kicad_sym”)
…truncated. See next post
…continued
(options “”)(descr “Texas Instruments DSP symbols”))
(lib (name “Fiber_Optic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Fiber_Optic.kicad_sym”)(options “”)(descr “Fiber optic symbols”))
(lib (name “Filter”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Filter.kicad_sym”)(options “”)(descr “Filter symbols”))
(lib (name “FPGA_Lattice”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Lattice.kicad_sym”)(options “”)(descr “Lattice FPGA symbols”))
(lib (name “FPGA_Microsemi”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Microsemi.kicad_sym”)(options “”)(descr “Microsemi FPGA symbols”))
(lib (name “FPGA_Xilinx”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx.kicad_sym”)(options “”)(descr “Assorted Xilinx FPGA symbols”))
(lib (name “FPGA_Xilinx_Artix7”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx_Artix7.kicad_sym”)(options “”)(descr “Xilinx Artix7 FPGA symbols”))
(lib (name “FPGA_Xilinx_Kintex7”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx_Kintex7.kicad_sym”)(options “”)(descr “Xilinx Kintex7 FPGA symbols”))
(lib (name “FPGA_Xilinx_Spartan6”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx_Spartan6.kicad_sym”)(options “”)(descr “Xilinx Spartan6 FPGA symbols”))
(lib (name “FPGA_Xilinx_Virtex5”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx_Virtex5.kicad_sym”)(options “”)(descr “Xilinx Virtex5 FPGA symbols”))
(lib (name “FPGA_Xilinx_Virtex6”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx_Virtex6.kicad_sym”)(options “”)(descr “Xilinx Virtex6 FPGA symbols”))
(lib (name “FPGA_Xilinx_Virtex7”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/FPGA_Xilinx_Virtex7.kicad_sym”)(options “”)(descr “Xilinx Virtex7 FPGA symbols”))
(lib (name “GPU”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/GPU.kicad_sym”)(options “”)(descr “Graphics Processing Units”))
(lib (name “Graphic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Graphic.kicad_sym”)(options “”)(descr “Graphical symbols”))
(lib (name “Interface”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface.kicad_sym”)(options “”)(descr “Assorted interface symbols”))
(lib (name “Interface_CAN_LIN”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_CAN_LIN.kicad_sym”)(options “”)(descr “CAN / LIN interface symbols”))
(lib (name “Interface_CurrentLoop”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_CurrentLoop.kicad_sym”)(options “”)(descr “Current loop interface devices”))
(lib (name “Interface_Ethernet”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_Ethernet.kicad_sym”)(options “”)(descr “Ethernet interface symbols”))
(lib (name “Interface_Expansion”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_Expansion.kicad_sym”)(options “”)(descr “I/O expansion devices, shift registers, etc”))
(lib (name “Interface_HDMI”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_HDMI.kicad_sym”)(options “”)(descr “High Definition Multimedia Interface (HDMI) symbols”))
(lib (name “Interface_HID”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_HID.kicad_sym”)(options “”)(descr “Human Interface Device (HID) symbols”))
(lib (name “Interface_LineDriver”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_LineDriver.kicad_sym”)(options “”)(descr “Line driver interface symbols”))
(lib (name “Interface_Optical”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_Optical.kicad_sym”)(options “”)(descr “Optical interfaces (IR receivers)”))
(lib (name “Interface_Telecom”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_Telecom.kicad_sym”)(options “”)(descr “Telecom interface symbols”))
(lib (name “Interface_UART”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_UART.kicad_sym”)(options “”)(descr “UART interface symbols”))
(lib (name “Interface_USB”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Interface_USB.kicad_sym”)(options “”)(descr “USB interface symbols”))
(lib (name “Isolator”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Isolator.kicad_sym”)(options “”)(descr “Isolator devices”))
(lib (name “Isolator_Analog”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Isolator_Analog.kicad_sym”)(options “”)(descr “Analog isolator devices”))
(lib (name “Jumper”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Jumper.kicad_sym”)(options “”)(descr “(Solder) jumper symbols”))
(lib (name “LED”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/LED.kicad_sym”)(options “”)(descr “Light Emitting Diode (LED) symbols”))
(lib (name “Logic_LevelTranslator”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Logic_LevelTranslator.kicad_sym”)(options “”)(descr “Logic level translators and level shifters”))
(lib (name “Logic_Programmable”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Logic_Programmable.kicad_sym”)(options “”)(descr “Programmable logic symbols”))
(lib (name “MCU_AnalogDevices”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_AnalogDevices.kicad_sym”)(options “”)(descr “Analog Devices microcontrollers”))
(lib (name “MCU_Cypress”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Cypress.kicad_sym”)(options “”)(descr “Cypress microcontrollers”))
(lib (name “MCU_Dialog”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Dialog.kicad_sym”)(options “”)(descr “Dialog Semiconductor microcontrollers”))
(lib (name “MCU_Espressif”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Espressif.kicad_sym”)(options “”)(descr “Espressif microcontrollers”))
(lib (name “MCU_Intel”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Intel.kicad_sym”)(options “”)(descr “Various Intel MCU devices and associated peripherals”))
(lib (name “MCU_Microchip_8051”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_8051.kicad_sym”)(options “”)(descr “Microchip 8051 microcontrollers”))
(lib (name “MCU_Microchip_ATmega”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_ATmega.kicad_sym”)(options “”)(descr “Microchip ATmega microcontrollers”))
(lib (name “MCU_Microchip_ATtiny”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_ATtiny.kicad_sym”)(options “”)(descr “Microchip ATtiny microcontrollers”))
(lib (name “MCU_Microchip_AVR”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_AVR.kicad_sym”)(options “”)(descr “Microchip AVR microcontrollers”))
(lib (name “MCU_Microchip_PIC10”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_PIC10.kicad_sym”)(options “”)(descr “Microchip PIC10 microcontrollers”))
(lib (name “MCU_Microchip_PIC12”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_PIC12.kicad_sym”)(options “”)(descr “Microchip PIC12 microcontrollers”))
(lib (name “MCU_Microchip_PIC16”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_PIC16.kicad_sym”)(options “”)(descr “Microchip PIC16 microcontrollers”))
(lib (name “MCU_Microchip_PIC18”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_PIC18.kicad_sym”)(options “”)(descr “Microchip PIC18 microcontrollers”))
(lib (name “MCU_Microchip_PIC24”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_PIC24.kicad_sym”)(options “”)(descr “Microchip PIC24 microcontrollers”))
(lib (name “MCU_Microchip_PIC32”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_PIC32.kicad_sym”)(options “”)(descr “Microchip PIC32 microcontrollers”))
(lib (name “MCU_Microchip_SAMA”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_SAMA.kicad_sym”)(options “”)(descr “Microchip SAMA microcontrollers”))
(lib (name “MCU_Microchip_SAMD”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_SAMD.kicad_sym”)(options “”)(descr “Microchip SAMD microcontrollers”))
(lib (name “MCU_Microchip_SAME”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_SAME.kicad_sym”)(options “”)(descr “Microchip SAME microcontrollers”))
(lib (name “MCU_Microchip_SAML”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_SAML.kicad_sym”)(options “”)(descr “Microchip SAML microcontrollers”))
(lib (name “MCU_Microchip_SAMV”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Microchip_SAMV.kicad_sym”)(options “”)(descr “Microchip SAMV microcontrollers”))
(lib (name “MCU_Module”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Module.kicad_sym”)(options “”)(descr “Microcontroller Modules and Breakouts (Arduino …)”))
(lib (name “MCU_Nordic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Nordic.kicad_sym”)(options “”)(descr “Nordic Semiconductor microcontrollers”))
(lib (name “MCU_NXP_ColdFire”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_ColdFire.kicad_sym”)(options “”)(descr “NXP ColdFire microcontrollers (formerly Motorola)”))
(lib (name “MCU_NXP_HC11”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_HC11.kicad_sym”)(options “”)(descr “NXP HC11 microcontrollers”))
(lib (name “MCU_NXP_HC12”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_HC12.kicad_sym”)(options “”)(descr “NXP HC12 microcontrollers”))
(lib (name “MCU_NXP_HCS12”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_HCS12.kicad_sym”)(options “”)(descr “NXP HCS12 microcontrollers”))
(lib (name “MCU_NXP_Kinetis”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_Kinetis.kicad_sym”)(options “”)(descr “NXP Kinetis microcontrollers”))
(lib (name “MCU_NXP_LPC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_LPC.kicad_sym”)(options “”)(descr “NXP LPC microcontrollers”))
(lib (name “MCU_NXP_MAC7100”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_MAC7100.kicad_sym”)(options “”)(descr “NXP MAC7100 (ARMv7-based) microcontrollers”))
(lib (name “MCU_NXP_MCore”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_MCore.kicad_sym”)(options “”)(descr “NXP M*Core microcontrollers”))
(lib (name “MCU_NXP_NTAG”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_NTAG.kicad_sym”)(options “”)(descr “NXP NFC microcontrollers”))
(lib (name “MCU_NXP_S08”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_NXP_S08.kicad_sym”)(options “”)(descr “NXP S08 microcontrollers”))
(lib (name “MCU_Parallax”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Parallax.kicad_sym”)(options “”)(descr “Parallax microcontrollers”))
(lib (name “MCU_Renesas_Synergy_S1”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Renesas_Synergy_S1.kicad_sym”)(options “”)(descr “Renesas Synergy S1 microcontrollers”))
(lib (name “MCU_SiFive”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_SiFive.kicad_sym”)(options “”)(descr “SiFive microcontrollers”))
(lib (name “MCU_SiliconLabs”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_SiliconLabs.kicad_sym”)(options “”)(descr “Silicon Labs (SiLabs) microcontrollers”))
(lib (name “MCU_STC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_STC.kicad_sym”)(options “”)(descr “STC microcontrollers”))
(lib (name “MCU_ST_STM8”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM8.kicad_sym”)(options “”)(descr “ST STM8 microcontrollers”))
(lib (name “MCU_ST_STM32F0”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32F0.kicad_sym”)(options “”)(descr “ST STM32F0 microcontrollers”))
(lib (name “MCU_ST_STM32F1”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32F1.kicad_sym”)(options “”)(descr “ST STM32F1 microcontrollers”))
(lib (name “MCU_ST_STM32F2”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32F2.kicad_sym”)(options “”)(descr “ST STM32F2 microcontrollers”))
(lib (name “MCU_ST_STM32F3”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32F3.kicad_sym”)(options “”)(descr “ST STM32F3 microcontrollers”))
(lib (name “MCU_ST_STM32F4”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32F4.kicad_sym”)(options “”)(descr “ST STM32F4 microcontrollers”))
(lib (name “MCU_ST_STM32F7”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32F7.kicad_sym”)(options “”)(descr “ST STM32F7 microcontrollers”))
(lib (name “MCU_ST_STM32G0”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32G0.kicad_sym”)(options “”)(descr “ST STM32G0 microcontrollers”))
(lib (name “MCU_ST_STM32H7”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32H7.kicad_sym”)(options “”)(descr “ST STM32H7 microcontrollers”))
(lib (name “MCU_ST_STM32L0”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32L0.kicad_sym”)(options “”)(descr “ST STM32L0 microcontrollers”))
(lib (name “MCU_ST_STM32L1”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32L1.kicad_sym”)(options “”)(descr “ST STM32L1 microcontrollers”))
(lib (name “MCU_ST_STM32L4”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32L4.kicad_sym”)(options “”)(descr “ST STM32L4 microcontrollers”))
(lib (name “MCU_ST_STM32L4+”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_ST_STM32L4+.kicad_sym”)(options “”)(descr “ST STM32L4+ microcontrollers”))
(lib (name “MCU_Texas”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Texas.kicad_sym”)(options “”)(descr “Texas Instruments microcontrollers (assorted)”))
(lib (name “MCU_Texas_MSP430”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Texas_MSP430.kicad_sym”)(options “”)(descr “Texas Instruments MSP430 microcontrollers”))
(lib (name “MCU_Texas_SimpleLink”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/MCU_Texas_SimpleLink.kicad_sym”)(options “”)(descr “Texas Instruments SimpleLink microcontrollers”))
(lib (name “Mechanical”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Mechanical.kicad_sym”)(options “”)(descr “Mechanical symbols”))
(lib (name “Memory_EEPROM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_EEPROM.kicad_sym”)(options “”)(descr “EEPROM memory”))
(lib (name “Memory_EPROM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_EPROM.kicad_sym”)(options “”)(descr “EPROM memory”))
(lib (name “Memory_Flash”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_Flash.kicad_sym”)(options “”)(descr “Flash memory”))
(lib (name “Memory_NVRAM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_NVRAM.kicad_sym”)(options “”)(descr “Non volatile RAM (NVRAM)”))
(lib (name “Memory_RAM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_RAM.kicad_sym”)(options “”)(descr “Volatile RAM”))
(lib (name “Memory_ROM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_ROM.kicad_sym”)(options “”)(descr “Read only memory (ROM)”))
(lib (name “Memory_UniqueID”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Memory_UniqueID.kicad_sym”)(options “”)(descr “UID and serial number memory devices”))
(lib (name “Motor”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Motor.kicad_sym”)(options “”)(descr “Motor symbols”))
(lib (name “Oscillator”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Oscillator.kicad_sym”)(options “”)(descr “Oscillator symbols”))
(lib (name “Potentiometer_Digital”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Potentiometer_Digital.kicad_sym”)(options “”)(descr “Digital potentiometers”))
(lib (name “power”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/power.kicad_sym”)(options “”)(descr “Power symbols, special power flags”))
(lib (name “Power_Management”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Power_Management.kicad_sym”)(options “”)(descr “Power management and distribution ICs”))
(lib (name “Power_Protection”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Power_Protection.kicad_sym”)(options “”)(descr “Power protection devices”))
(lib (name “Power_Supervisor”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Power_Supervisor.kicad_sym”)(options “”)(descr “Power supervisory devices”))
(lib (name “pspice”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/pspice.kicad_sym”)(options “”)(descr “Legacy pspice symbol library.”))
(lib (name “Reference_Current”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Reference_Current.kicad_sym”)(options “”)(descr “Precision current references”))
(lib (name “Reference_Voltage”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Reference_Voltage.kicad_sym”)(options “”)(descr “Precision voltage references”))
(lib (name “Regulator_Controller”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Regulator_Controller.kicad_sym”)(options “”)(descr “Power regulator controllers”))
(lib (name “Regulator_Current”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Regulator_Current.kicad_sym”)(options “”)(descr “Current regulators”))
(lib (name “Regulator_Linear”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Regulator_Linear.kicad_sym”)(options “”)(descr “Linear regulators”))
(lib (name “Regulator_SwitchedCapacitor”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Regulator_SwitchedCapacitor.kicad_sym”)(options “”)(descr “Switched capacitor / charge pump regulators”))
(lib (name “Regulator_Switching”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Regulator_Switching.kicad_sym”)(options “”)(descr “Switch-mode regulators”))
(lib (name “Relay”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Relay.kicad_sym”)(options “”)(descr “Relay symbols”))
(lib (name “Relay_SolidState”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Relay_SolidState.kicad_sym”)(options “”)(descr “Solid state relays (Transistor and Triac based)”))
(lib (name “RF”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF.kicad_sym”)(options “”)(descr “Assorted / uncategorized Radio Frequency (RF) devices”))
(lib (name “RF_Bluetooth”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_Bluetooth.kicad_sym”)(options “”)(descr “RF Bluetooth wireless modules”))
(lib (name “RF_AM_FM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_AM_FM.kicad_sym”)(options “”)(descr “AM / FM wireless devices”))
(lib (name “RF_Amplifier”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_Amplifier.kicad_sym”)(options “”)(descr “RF amplifier symbols”))
(lib (name “RF_Filter”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_Filter.kicad_sym”)(options “”)(descr “RF filter symbols”))
(lib (name “RF_GPS”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_GPS.kicad_sym”)(options “”)(descr “GPS devices”))
(lib (name “RF_GSM”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_GSM.kicad_sym”)(options “”)(descr “GSM devices”))
(lib (name “RF_Mixer”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_Mixer.kicad_sym”)(options “”)(descr “RF mixer symbols”))
(lib (name “RF_Module”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_Module.kicad_sym”)(options “”)(descr “RF module symbols”))
(lib (name “RF_NFC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_NFC.kicad_sym”)(options “”)(descr “Near Field Communication (RFID)”))
(lib (name “RF_RFID”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_RFID.kicad_sym”)(options “”)(descr “Radio Frequency ID (RFID)”))
(lib (name “RF_Switch”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_Switch.kicad_sym”)(options “”)(descr “RF switch symbols”))
(lib (name “RF_WiFi”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_WiFi.kicad_sym”)(options “”)(descr “WiFi symbols”))
(lib (name “RF_ZigBee”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/RF_ZigBee.kicad_sym”)(options “”)(descr “ZigBee / XBee symbols”))
(lib (name “Security”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Security.kicad_sym”)(options “”)(descr “Security devices”))
(lib (name “Sensor”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor.kicad_sym”)(options “”)(descr “Multi-function sensors, assorted sensors”))
(lib (name “Sensor_Audio”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Audio.kicad_sym”)(options “”)(descr “Audio / sound / microphone sensors”))
(lib (name “Sensor_Current”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Current.kicad_sym”)(options “”)(descr “Current sensors”))
(lib (name “Sensor_Distance”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Distance.kicad_sym”)(options “”)(descr “Distance sensors”))
(lib (name “Sensor_Gas”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Gas.kicad_sym”)(options “”)(descr “Gas sensors”))
(lib (name “Sensor_Humidity”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Humidity.kicad_sym”)(options “”)(descr “Humidity sensors”))
(lib (name “Sensor_Magnetic”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Magnetic.kicad_sym”)(options “”)(descr “Magnetic field and hall-effect sensors”))
(lib (name “Sensor_Motion”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Motion.kicad_sym”)(options “”)(descr “Accelerometers, gyroscopic sensors”))
(lib (name “Sensor_Optical”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Optical.kicad_sym”)(options “”)(descr “Light and color sensors”))
(lib (name “Sensor_Pressure”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Pressure.kicad_sym”)(options “”)(descr “Fluid and mechanical pressure sensors”))
(lib (name “Sensor_Proximity”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Proximity.kicad_sym”)(options “”)(descr “Optical interuption and proximity (optical, inductive, capacitve, …) sensors”))
(lib (name “Sensor_Temperature”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Temperature.kicad_sym”)(options “”)(descr “Temperature sensors”))
(lib (name “Sensor_Touch”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Touch.kicad_sym”)(options “”)(descr “Touch sensors”))
(lib (name “Sensor_Voltage”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Sensor_Voltage.kicad_sym”)(options “”)(descr “Voltage sensors”))
(lib (name “Simulation_SPICE”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Simulation_SPICE.kicad_sym”)(options “”)(descr “Symbols specialized for SPICE circuit simulation (including ngspice).”))
(lib (name “Switch”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Switch.kicad_sym”)(options “”)(descr “Switch symbols”))
(lib (name “Timer”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Timer.kicad_sym”)(options “”)(descr “Assorted timer devices”))
(lib (name “Timer_PLL”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Timer_PLL.kicad_sym”)(options “”)(descr “Phase locked loop (PLL) devices”))
(lib (name “Timer_RTC”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Timer_RTC.kicad_sym”)(options “”)(descr “Real time clock (RTC) devices”))
(lib (name “Transformer”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Transformer.kicad_sym”)(options “”)(descr “Transformer symbols”))
(lib (name “Transistor_Array”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Transistor_Array.kicad_sym”)(options “”)(descr “Specialized transistor arrays”))
(lib (name “Transistor_BJT”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Transistor_BJT.kicad_sym”)(options “”)(descr “BJT transistor symbols”))
(lib (name “Transistor_FET”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Transistor_FET.kicad_sym”)(options “”)(descr “FET transistor symbols”))
(lib (name “Transistor_IGBT”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Transistor_IGBT.kicad_sym”)(options “”)(descr “IGBT transistor symbols”))
(lib (name “Triac_Thyristor”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Triac_Thyristor.kicad_sym”)(options “”)(descr “TRIAC and thyristor symbols”))
(lib (name “Valve”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Valve.kicad_sym”)(options “”)(descr “Valve symbols”))
(lib (name “Video”)(type “KiCad”)(uri “${KICAD6_SYMBOL_DIR}/Video.kicad_sym”)(options “”)(descr “Video symbols”))
----the end
You still have some 2021etc version packages installed:
You need to delete those then install, and then you will get the 6.0.1 versions. Probably:
sudo apt remove kicad-footprints kicad-symbols kicad-templates
sudo apt install kicad-footprints kicad-symbols kicad-templates
THAT WORKED!!!
THANK YOU THANK YOU THANK YOU.
Why isn’t that part of the install package by KiCad???
I can now access libraries including the grnds and pwr symbols. And my schematics, even with custom parts, are fine.
Next, I’ll go test the PCB and see if footprints are working…HAH!
Trippy.
I have thousands of hours of work with OrCad over 27 years or so and although there were some glitches, I recall nothing like these types of errors when upgrading or updating KiCad. Of course I’m using the much preferred Ubuntu on Linux now instead of WinDoze. And KiCad is freeware so can’t complain. Want to, but can’t. It’s the law.
In the normal course of events those library packages would be pulled in by an install of the main KiCad package, but the presence of a number of packages with a different numbering scheme made them unupgradable, so they stayed stuck.
It’s not your fault and hopefully such versioning glitches will not happen again.
So where would these packages exist?
From one of those 2021 testing repos for 5.99, you can try to match the package version which contains the Ubuntu release version with the obsolete repo lines in OP’s first post. The packages may not even be there any more, but once installed, their version is greater than any 5 or 6 version.
Thanks,
I upgraded the Ubuntu versions innumerable times over 2021 but never suffered that problem. I was just curious… will try to remember :crazy_face:
