Hi
I would be very glad if someone could tell me whats the part on my screenshot.
I try to build an own kind of motherboard and got stuck at this point.
Thanks in advance
BeHa
Hi
Thanks in advance
BeHa
Isn’t this just a resistor array? In KiCad R_Network or R_Pack. Several resistors in one physical package.
I am not quite sure because my picture is from the manufacturer and I do not think that they use kicad
It is very likely a resistor array of 4 resistors with a value of 56 Ohm in a 0408 package.
0408 is a pretty small SMD component. Look at the smallest SMD’s you see in:
https://duckduckgo.com/?q=resistor+array+0408&iax=images&ia=images
When you see values like that on a motherboard, you are usually looking a some sort of transmission line matching. Modern motherboards have controlled impedance and length tuning.
