I just downloaded the latest 5.1.9 release build and keep running into this problem in both footprint editor and Pcbnew. When I select a part or a graphic line in footprint editor or Pcbnew, it sometimes shows the item is selected, but I can’t delete or view the properties all the time. Sometimes it takes multiple de-selects and re-selects before I can do something with it like using the ‘E’ shortcut to view the properties. I first ran into this when I re-annotated a block of parts and wanted the re-annotated parts to be in the same spot as the old parts (I forget what option I use to keep the original parts while the new parts are brought in using the update from schematic command, since KiCad will just blow away the old ones and I lose their positioning if I don’t do this, even if I have renamed the old references to the new ones). So now I want to copy and paste the X and Y coordinate of each old part into the re-annotated part, deleting the old part just before I change the new part’s coordinates to match the old part. This is where I first ran into the issue of not being able to view the property of the old or new part after selecting it consistently. Sometimes it takes multiple selects/de-selects before I can see the property window. I also can’t delete a part or do anything else with it even though it is clearly showing it is selected when it is acting this way. I have to de-select and re-select and hope it works the next time. Although if I try enough times, I can get through the operation.
Which brings me what I was doing today, which is editing a footprint for a coin cell battery. I’m having a heck of a time moving and editing some courtyard lines. They show selected but just like with Pcbnew, I can’t do anything to the selection such as view the properties or move or delete the object. It actually seems worse in footprint editor since I’ve tried selecting and re-selecting some of the courtyard graphics objects dozens of times for some of them whereas in Pcbnew USUALLY 3-5 selection/de-selection cycles is enough to allow me to view the property or delete the object.
Has anyone seen this? I only started using KiCad recently (first version was 5.1.8) and I don’t recall seeing this in that version but I was mostly doing schematic capture for this project then, so it may also exist in earlier versions.
