Cannot select locked footprint
I have two connectors that were locked so their positions would not get moved during PCB design. I am not able to select either connector now. Using the “interactive edit tool”, the connector is highlighted with small message “item locked”.
Okay… so how do I unlock it? Edit feature does nothing. Pressing L or Alt L or shift L does nothing. How do I unlock the footprint so I can modify it?
Thank you.
Use the “selection filter” which controls what can be selected and what can’t.
Thank you for the reply. I am using 6.0.10 and there is not a “selection filter” that I can find.
Under EDIT drop down menu there is a “Interactive Delete Tool” that sort of does what you are showing, but only option is to delete the footprint.
Thank you.
On the bottom right of the screen. You have to enable/display the appearance panel. (View–>Show appearance manager).
Got it! Thank you ever so much for your patience. Goldfish memory here needed a reminder of the tool’s location.
