I try to import a 400x400px image.
On this image i’ve made multiple measures. There are a few lines with the size next to them.
I try to calculate the same size in KiCad with the measurement tool, but it just can’t get the right size.
For the DPI setting, i’ve did :
400x25.4/105.83
which is {size in pixel}x25.4/{size in mm}
and i get 96. Tho, when i measure it in Kicad it’s not correct.
Then i go by trials and errors to get the correct size; a bit more, a bit more, a bit less, etc.
But now that i am very near the correct size, it’s OR too big, OR too small. And i can’t put comma in Bitmap2Component.
Do you have any tricks ?
Thanks
( I want to import this image to place components in the correct position )
