I am trying to insert an outline to create a footprint, however when I try to import the .dxf file I get this message.
Does anyone know where I enable or download such plugin to handle .dxf files or is my .dxf the error? I created the .dxf from a solidworks part I created.
What is the capitalization of the filename? Did you use .DXF? There is a bug in 5.1.4 on Windows that will only import a dxf file if the extension is all lowercase (so it must be filename.dxf, not filename.DXF). This is fixed in the current 5.1 nightlies, and will be released with 5.1.5.
Hi, I checked and it is .dxf (Lowercase). I got it work finally and I am able to import the file now, But this is real good to know. I appreciate your response, Thank you!!!
I can confirm that this also a bug in the mac version of KiCad 5.1.4
Changed the case of the suffix in my dxf file and it did import properly after failing with DXF.
