I have created a symbol but i cannot draw a wire on the circle on one of the pins. I have uploaded an image. If you look closely on (1), the node is not on a dot.
Instead if you look at (2), the node on the resistor is on a dot and i can draw a wire on that.
I want to connect the two, but while i can draw a wire on the resistor, i cannot on the pin.
Thanks!
