Cannot connect U1 pin 8 to anything
I am using V5.1.4, Win7x64 - I am new to Kicad - trying a simple battery alarm ckt with thru hole components, single component side, traces on back. I have tried several op amp symbols (LM358 or LM2904) and several footprints (8 pin DIP) & all seem to have same issue. Relocating Pwr & VCC had no luck. The file attached is as close as I have come, but trace is still not connected. Any ideas will be appreciated.
Joe
Bat Alarm.kicad_pcb (62.3 KB)
Bat Alarm.sch (6.6 KB)
The schematic cannot be seen if you don’t send at least the BatAlarm-cache.lib.
You need to add at least unit C to your schematic.
2904/358 consists of two op-amps.
  • Unit A (3+, 2-, y3)
  • Unit B (5+, 6-, y7)
  • Unit C (8V+, 4V-)
Try attached zip containing the necessary changes. You may need to rearrange as required.
Cheers
Bat Alarm.zip (17.2 KB)
ERC detecting unused units has been put forwards
“Me too” it
Thanks for the replies! I am attaching the whole file - maybe it will make better sense.Bat Alarm.zip (19.8 KB)
Thanks Jos - I finally got the picture. I did try attaching a Digikey symbol which included power/gnd but it did not work either. I added the ‘C’ unit from the lib & all is well!
