Hi All~~
When do you pour copper, Could you make it the following case?
- Copper clearance trace clearance: 0.3mm
- Edge line clearance: 1mm?
If it doesn’t work, what do you do?
I made keepout area.
Hi All~~
simple approach: use the Board setup → Design-Rules–>Constraints and set different values for:
Additionally you can override these values with the Copper-Zone-Properties → Electrical Clearance (only in the direction of greater values)
If you have more detailed requirements you can use the custom rules feature.
For more clearance zone-board-outline for instance:
#example for extra-clearance zone to Board-edge
#the zone needs a name set in the zone-properties-dialog, in this case: EXAMPLE_ZONE
(version 1)
(rule “Clearance zone to board-edge”
(constraint clearance (min 1.5mm))
(condition “A.Type ==‘Zone’ && A.Name ==‘EXAMPLE_ZONE’ && B.Layer ==‘Edge.Cuts’”))
keepout-area != copper fill zone
wow Thank you so much!!~~~
Thank you!!~~~
