Can python script manipulate the ratsnet drawing?
I’m wondering if python script can change rastnet drawing, topology, or event multiple lines per pin to pin.
No, ratsnest lines are not part of the data model, they are based on information calculated from netlist and runtime connectivity check. You can manipulate netlist from python but you can’t force pcbnew to draw particular lines for particular pins. It has it’s own runtime algorithm that chooses where to draw the lines, mostly based on closest points between already connected parts of the net.
