I have designed 2 separate Schematics and PCB layouts and Now I’m wondering if there is any way to merge the 2 of them together to then modify slightly and then created a 3rd PCB where both PCB’s designs are on a new PCB design.
Is there any suggested way of doing this? I prefer to not have to start from scratch if possible.
If you are just trying to make a panel that contains two or more layouts, then just start pcbnew by itself without starting the entire KiCad application. Then open one of the .kicad_pcb files. Then, use the File => Append Board command to bring in another PCB layout. You can do that multiple times to bring in as many other layouts as you want.
If you want to merge two schematics, you could create a master schematic and add hierarchical pages that each refer to one of your existing schematic files (you’ll have to move your existing schematic files into the master project directory). Then you should be able to make connections between the hierarchical pages using global or hierarchical labels. I’m not sure if you could merge the existing PCB layouts as well and have it matchup with the merged schematic netlist. I’ve never done that.
Why do we have to open a new PcbNew application instead of simply creating a new pcb_new file in the project? (Creating another file in the project does not let you use “append board” option, it is disabled in the menu.)
Why does not appended boards are updated when they are changed? Does this facility only copies and pastes the content of the board?
There is no problem with the separate project requirement for now. I may handle this later. But I can not find any option to “import” or include another project in my current project…
The output of Kicad is designed to make a single PCB, so it doesn’t make any sense to include another project. If you are hoping that changes in a project are going to automatically propagate to another project like a #include “subproject” statement, forget it, that is not going to happen.
Really, these philosophy / hypothetical ideas are not going to lead anywhere. KiCad is what it is. It is best to learn how KiCad works, then go with the flow.
You have to get a way to generate your PCB as a VRML model. And then, import it as a footprint with 3D shape models. (EDIT: I mean what @bobc said in the next post)
Maybe this tool can be helpful, have a look at StepUp:
Hey, don’t confuse the guy further. You can’t “import a 3D model as a footprint”. You can create a footprint, and then attach a 3D model, but the 3d model has zero effect on the copper layout.
I like this answer but having problems with doing it.
I’m trying to combine 3 PCB designs for a prototype run to get a lower cost on the first version of each of three designs and get a single stencil to assemble these first prototypes.
Later I will panelize a single design with say a 2x3 array (Qty 6) to fit into a toaster over.
For now, to give these instructions a try, I found the pcbnew application and started it as Administrator (version below)
Application: Pcbnew
Version: (2013-05-31 BZR 4019)-stable
Build: wxWidgets 2.9.4 (wchar_t,compiler with C++ ABI 1002,GCC 4.7.2,wx containers,compatible with 2.8)
Boost version: 1.53.0
Options: USE_PCBNEW_NANOMETRES=ON
KICAD_GOST=OFF
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=OFF
KICAD_SCRIPTING_MODULES=OFF
KICAD_SCRIPTING_WXPYTHON=OFF
When I try to open any one of a few layouts I get this error message. I basically get the same error on several layouts I have tried. Any clue what is going on?
TIA
EDIT: I got something to work but not following the directions
1.) I started KiaCAD as administrator
2.) opened a complete PCB layout using pdbnew from the project.
3.) “save as” from pcbnew as XXXX_prototype.
I closed Kicad.
4.) I then used windows explorer to open the XXX_prototype.kicad_pcb file pointing to pcbnew.
5.) Now with the first PCB in the layout I started using “Append board” to add two others.
These designs share a lot of net names as they are very similar mainly differing in layouts. So I now start getting rats nests. I am leary of doing any DCR checks as I can do all of that as individual designs.
Unfortunately no; you will be forced to reannotate and lose the mapping of the reference descriptors. This is one of those areas which requires some work; at the moment it is especially annoying for people who have a circuit module which may be reused many times in a single PCB design.
Before KiCAD can do that a lot of water will have flown down the rivers.
Again, just to be clear - you won’t be able to get 2 or more projects (schematics + layouts) to become one project, where each schematic is linked with it’s respective layout.
People are working on this (afaik) to make this possible, but it’s NOT around the corner.
If you just want to create a panel from finished layouts (no links to schematics) you can do this:
On page 6-th there are some description about Team Work. It work that the PCB file in Board Station are ASCII files, and the merging is easy, as could be in KiCad.
It is rare in electronic to start the schematic for scratch, mainly there are several sheet used for old project, like power supply, DC-DC converters, the processor- memory unit, front-end amplifiers, ADC.
Mainly connected hierarchically. But the new one is the PCB board, rare could be stick together the old PCB, board, mostly the PCB have to be made for scratch.
PCB collaboration is to one of the methodology to speed up the time to complete the PCB. Each “PCB draftsman” are the own PCB area, and route the connection. After each complete, the whole PCB board was marge for each PCB.
The same methodology use the Altium PCB Collaboration, using the SVN.
I hope the KiCad going into GIT versioning, creating this useful features.
Are both desings part of one PCB? Could you join them also on schematci level? If yes, you could make a nwe kicad project with hiearchical design. Then you add two hierarchical sheets and you point them to original schematic files. Then you open original project layout and save the layout using Save/restore action plugin. Then you restore the layout in newly created project.
I am not sure that this is what you wanted though.
