After deletion of parts of the schematic pages in a project and a successive update of the layout from the schematic (F8), all deleted components are deleted as intended. However, the tracks and via’s must be deletes manually.
I found the following:
When I highlight a nameless net (key `), all the nameless nets are highlighted (I did not expect that). That’s fine. But as far as I see (and know) you cannot convert a highlight status into a select status. Then it would be super easy to have the layout matched with a reduced schematic.
Does Tools > Cleanup Tracks & Vias not do what you want?
Thanks for replying. You reminded me of the tools menu, which hasn’t been visited since a certain time. I remembered something like Cleanup Tracks, but only saw Global deletions in the edit menu.
Cleanup works, but some nameless nets are still present. That however is removed quite easy.
