Can footprints be rotated by an arbitrary angle (not 90 degrees)?
If not, does a script exist (or can one be written) that can perform that task?
Select the desired footprint on the board, right-click in the list, find the placement tool (move exactly)
Thanks! Exactly what I was looking for. I really did do a search in the docs on “rotate”, as well as other keywords, but found nothing. Thanks again.
And because “more” is always better another two workflow-options to change the orientation of footprints to arbitrary values:
some notes:
Who tells you to remember all the workflows?
Each user can only remember one workflow. The easiest for him, or the only one he happened to find. But if there are 5 workflows available it is higher chance to find one of them if you don’t know where they are.
I used to be skeptical of the need to rotate components at angles other than multiples of 90 degrees. (OK but what about angles such as 990 degrees? Is that dizzying?) But a couple of years ago I designed a two layer board which had a bunch of wire jumpers on it. The jumpers were jumping over multiple tracks, and I found it very helpful to use some odd angles. Maybe that was due to some other aspects of my layout. But anyway the board worked OK.
