I have just started to dabble in Pspice (the Cadence product).
From what I can see, the version that I am working with (which is the up-to-date download) uses the *.lib file extension for SPICE models. Apparently, from what I have been able to glean in a short time working with Pspice (again, I am just a total newbie to Pspice…), in previous Pspice versions those files had the *.mod extension.
I would like to keep the Pspice files in the same super-folder (directory structure) that contains my KiCad project files. It appears that Pspice creates a local, project-specific directory of “SPICE models” (rather than, by default, fetching those from the a distant repository) for each of its Projects. So… if the Pspice files and the KiCad files are in the same folder structure, it could be that the identical File Extension will confuse one, the other, or both of these applications.
Before Something Bad happens, does anybody have suggestions as to how one can avoid conflicts with KiCad…which uses the *.lib extension for schematic symbols ?
