First there was a unique footprint for 0402 components (SMD). This library was split in Capacitors_SMD and Resistors_SMD.
But the C_0402 has very big pads comparing to R_0402. Is there any reason for having so big pads ?
Thanks
Thanks
Capacitors usually have larger tolerances.
You normally need more solder paste and area to successfully solder a 0402 capacitor. This is due to the capacitor normally been larger in height in comparison to a 0402 resistor.
-Ron
As someone who recently had to place a 0805 capacitor in a 0603 footprint (don’t ask), I no longer complain about the larger pads.
For a more authoritative answer, IPC7351 defines the footprints as being larger for a capacitor of the same nominal size. Opticalworm has the right idea - the capacitor is taller, so a larger pad area is needed to keep the aspect ratio of the solder joint reasonable.
