I know there are a few other posts like this, but I can’t seem to find anything with this exact issue.
A project that has been clean of ERC errors for a while recently started throwing an error for almost every bus connection. I have not updated KiCAD recently and am currently on 6.0 running on Windows 11. I’ve created a sample project to demonstrate the types of issues.
I have a bus connected across a hierarchical sheet.
- Wires A & B on the bus have a No-connect in the root sheet but are connected to another component inside the sheet, and they throw no ERC errors.
- Wires C & D are connected to something in the root sheet. They throw 2 ERC errors each, as though KiCAD is not recognizing that the two ends of the wire should be connected.
- Wires E & F have no connect flags in the root sheet. They throw 1 ERC error each inside the hierarchical sheet.
When I switch to the PCB editor, all the connections are made correctly.
Is something wrong with my bus labelling? Or does this seem like an ERC bug?
