Perhaps this is just a cosmetic concern – I have done a lot of buses, but this is the first time I have run a bus to more than one sheet, and on the root page I see no way to add a second hierarchical label in a sheet block. Here I have an i2c bus going to two blocks. Can a second bus label be added? Does it even matter if it is blank or I just put text there? Does the bus need to split outside the blocks?
Version: 7.0.9, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.1.1
FontConfig 2.14.2
libcurl/8.4.0-DEV OpenSSL/3.1.4 zlib/1.3 nghttp2/1.56.0
Platform: Freedesktop.org SDK 23.08 (Flatpak runtime), 64 bit, Little endian, wxGTK, pop, x11
Date: Nov 14 2023 06:02:46
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.7.2
Curl: 8.4.0-DEV
ngspice: 41
Compiler: GCC 13.2.0 with C++ ABI 1018
KICAD_SPICE=ON
