I try to compile KicadLibrarian on linux but make fails. Does someone suceeded to compile on recent xubuntu 20.04?
make report:
Scanning dependencies of target kicadlibrarian
[ 6%] Building CXX object CMakeFiles/kicadlibrarian.dir/librarymanager.cpp.o
[ 13%] Building CXX object CMakeFiles/kicadlibrarian.dir/libmngr_dlgnewfootprint.cpp.o
[ 20%] Building CXX object CMakeFiles/kicadlibrarian.dir/libmngr_dlgnewsymbol.cpp.o
[ 26%] Building CXX object CMakeFiles/kicadlibrarian.dir/libmngr_dlgoptions.cpp.o
[ 33%] Building CXX object CMakeFiles/kicadlibrarian.dir/libmngr_dlgreport.cpp.o
[ 40%] Building CXX object CMakeFiles/kicadlibrarian.dir/libmngr_dlgtemplate.cpp.o
[ 46%] Building CXX object CMakeFiles/kicadlibrarian.dir/libmngr_frame.cpp.o
/home/slavko/Downloads/KiCad-Librarian-master/src/libmngr_frame.cpp:4206:68: error: expected ‘;’ at end of member declaration
4206 | virtual wxDirTraverseResult OnFile(const wxString& /filename/) wxOVERRIDE {
/home/slavko/Downloads/KiCad-Librarian-master/src/libmngr_frame.cpp:4206:70: error: ‘wxOVERRIDE’ does not name a type
/home/slavko/Downloads/KiCad-Librarian-master/src/libmngr_frame.cpp:4209:62: error: expected ‘;’ at end of member declaration
4209 | virtual wxDirTraverseResult OnDir(const wxString& dirname) wxOVERRIDE {
/home/slavko/Downloads/KiCad-Librarian-master/src/libmngr_frame.cpp:4209:64: error: ‘wxOVERRIDE’ does not name a type
make[2]: *** [CMakeFiles/kicadlibrarian.dir/build.make:141: CMakeFiles/kicadlibrarian.dir/libmngr_frame.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:76: CMakeFiles/kicadlibrarian.dir/all] Error 2
make: *** [Makefile:152: all] Error 2
A link to the project you want to build might be a good idea.
https://www.compuphase.com/electronics/kicadlibrarian_en.htm
I was thinking that is common for kicad users.
Never used this project. Looks like it has some handy features but I suggest you to not use for a while for two reasons.
- It has a little bit dated code base. Last commit is from two years earlier. Since KiCad has changed library format it might create problems rather than solving existing ones.
- You should keep the native way at the beginning so you can speed yourself up and get the whole idea working with KiCad.
