I am trying to build Kicad from source on Linux Mint 19.1 and I have the following error :
-- The C compiler identification is GNU 7.4.0
-- The CXX compiler identification is GNU 7.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Changing KICAD_SCRIPTING to ON as needed by KICAD_SCRIPTING_ACTION_MENU
-- KiCad install dir: </usr/local>
-- Looking for malloc.h
-- Looking for malloc.h - found
-- Looking for iso646.h
-- Looking for iso646.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for strcasecmp
-- Looking for strcasecmp - found
-- Looking for strncasecmp
-- Looking for strncasecmp - found
-- Looking for strtok_r
-- Looking for strtok_r - found
-- Looking for malloc - found
-- Looking for math.h
-- Looking for math.h - found
-- Looking for C++ include cmath
-- Looking for C++ include cmath - found
-- Looking for asinh
-- Looking for asinh - found
-- Looking for acosh
-- Looking for acosh - found
-- Looking for atanh
-- Looking for atanh - found
-- Performing Test HAVE_CMATH_ISINF
-- Performing Test HAVE_CMATH_ISINF - Success
-- Looking for clock_gettime in rt
-- Looking for clock_gettime in rt - found
-- Looking for gettimeofday
-- Looking for gettimeofday - found
-- Looking for getc_unlocked
-- Looking for getc_unlocked - found
-- Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE
-- Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE - Success
-- Performing Test COMPILER_SUPPORTS_WVLA
-- Performing Test COMPILER_SUPPORTS_WVLA - Success
-- Performing Test COMPILER_SUPPORTS_WSHADOW
-- Performing Test COMPILER_SUPPORTS_WSHADOW - Success
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
-- Found GLEW: /usr/include
-- Check for installed GLEW -- found
-- Found GLM: /usr/include (found suitable version "0.9.9.0", minimum required is "0.9.5.1")
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.58.0")
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for module 'cairo'
-- Found cairo, version 1.15.10
-- Found Cairo: /usr/lib/x86_64-linux-gnu/libcairo.so (found suitable version "1.15.10", minimum required is "1.12")
-- Checking for module 'pixman-1'
-- Found pixman-1, version 0.34.0
-- Found Pixman: /usr/lib/x86_64-linux-gnu/libpixman-1.so (found suitable version "0.34.0", minimum required is "0.30")
-- Boost version: 1.65.1
-- Found the following Boost libraries:
-- regex
-- Found ngspice: /usr/local/include
-- Found SWIG: /usr/bin/swig3.0 (found suitable version "3.0.12", minimum required is "3.0")
-- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.15", minimum required is "2.6")
-- Check for installed Python Interpreter -- found
-- Python module install path: lib/python2.7/dist-packages
-- Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython2.7.so (found suitable version "2.7.15rc1", minimum required is "2.6")
-- Found wxWidgets: -L/usr/local/lib;-pthread;;;-lwx_gtk3u_gl-3.0;-lwx_gtk3u_aui-3.0;-lwx_gtk3u_adv-3.0;-lwx_gtk3u_html-3.0;-lwx_gtk3u_core-3.0;-lwx_baseu_net-3.0;-lwx_baseu-3.0;-lwx_baseu_xml-3.0;-lwx_gtk3u_stc-3.0 (found suitable version "3.0.4", minimum required is "3.0.0")
-- Found Doxygen: /usr/local/bin/doxygen (found version "1.8.16") found components: doxygen missing components: dot
error: Cannot open file /home/olivier/Téléchargements/Kicad-source/kicad/build/release/CMakeDoxyfile.tpl for writing
CMake Error at /usr/share/cmake-3.10/Modules/FindDoxygen.cmake:630 (message):
Unable to generate Doxyfile template: 1
Call Stack (most recent call first):
CMakeLists.txt:807 (find_package)
I ran the command
sudo cmake -DCMAKE_BUILD_TYPE=Release -DKICAD_SCRIPTING=OFF -DKICAD_SCRIPTING_MODULES=OFF -DKICAD_SCRIPTING_WXPYTHON=OFF ../../
because I was not able to find what the issue was with wxPython/Phoenix.
I have Doxygen installed version 1.8.13-10
I tried to install the kicad ppa but it didn’t help.
Any idea what the problem is ?
Thank you for your help
