Building board incombination with point to point in a vacuum tube amplifier
The issue I’m having is that some of the tubes that I use, there is no footprint in the software that I could put on a PCB board. I’m looking for the footprint for a 6AS7, and a 6ns7. So what I’m doing, is I was going to use a terminal board to do a point to point connection to the vacuum tubes but I’m having difficulty with the circuit because I’m unsure on how to close the circuit board in combination to a point to point wiring. My question is how do I show the voltages leaving the terminal board on my PCB diagram ,so that the circuit finally looks closed.
Use a connector on one side, and a socket on the other.
What you need is the footprint of the tube socket for which I have seen board mount versions. If you are doing point to point wiring to sockets mounted on a chassis then you can make a footprint of an array of (circular) pads. In either case assign the footprint to the tube symbol.
Have you thought about making your own sockets? something like:
  1. Find female connector pins that are compatible with the pin thickness of your tube pins.
  2. Put shrink tube around it.
  3. Poke holes in a piece of paper, and put that on the bottom of the tube (stick the tube pins through the holes).
  4. Put the individual female sockets on the pins of the tube.
  5. Add a generous blob of glue. Silicone chaulk may work, or some other filling glue.
  6. Let it dry and clean it up.
By coincidence, I made this 6SN7 STEP file a few years ago for a Kicad user…
You can make your own Footprint and link to the STEP…
Tube_6SN7_r1.step (65.5 KB)
Here are links to my KiCad Projects Website that may be useful for this subject.
IFX KiCad Works
https://www.invntfx.com/_ifxkicad/_ifxkicad.htm
Valve/Tube Projects
IFX Valve/Tube Web Page
https://www.invntfx.com/_ifxkicad/_ifxkicadvlv.htm
Inventor eFX KiCad Project Extras Web Page
Custom Designed for the Projects:
3D STP & WRL Models
Footprint Libraries
Symbols Library
IFX Extras Webpage
https://www.invntfx.com/_ifxkicad/_ifxkicadxtra.htm
In British English they’re referred to as valves instead of tubes. The standard libraries have both valve symbols and footprints.
