I’m having issues where on a tight array of wide TO-92 footprints, trace clearances are not honored.
I’ve this on 3 different projects (2 from scratch specifically to test this with default library parts), tested on 7.0.5 and 7.0.6 as well as on a windows and linux machine.
Has anyone else been able to replicate this? Any good workarounds? (other than “carefully route” )
The pads in question have “Clearance Overrides and Settings” set to 0.
Board configuration: Clearances set to 1mm, still have issues (as per video, note how clearance rings indicate the required clearance, then as I move around, it tries to route around it, but in some cases ignores it?, it’s when it ignores it: that’s happening very often and is the issue).
With smaller “Minimum clearance” it get’s harder to provoke the clearance-violation, but I was able to create one with “Minimum clearance”==0.4mm (needed playing with finer grid and careful mouse.movement). I think the bug is buried in the router-code, the minimum clearance parameter makes it only harder/easier to discover.
