I couldn’t find Help->Report bug
I had made an error in the Schematic: A CAP had the Value anf the reference the wrong way round. After I corrected it, I got this: when bringing it into PCB.
Camerart
Camerart
There are now approximately 1500 open issue on gitlab, and not enough people working on that list, it is still growing…
I like to have a look at your project, to see if I can reproduce this error.
Maybe I could also do some cleanup. I saw for example you used the spice capacitors as schematic symbols instead of KiCad’s “normal” (and neater) capacitors.
I can also write the bug report if I can reproduce the error.
If you like this, then zip your project and upload it here.
@paulvdh
Hi P,
I have had similar issues with other project, where the error is e,g, ‘line 1 whould be 2’ somthing like that.
This one occured after I had corrected lots of error. I imagine, that I confused the syspem, by messing about.
I’ll try to repoduce it, and let you know if I can.
Thanks.
C
