[BUG?] Libraries Missing from Set Active Library menu in Footprint Editor (solved)
Hi all
I’ve been bashing my head up against this for the past two days and I’ve given up and come for help. Some of my user specific footprint libraries refuse to show up in the “Set Active Library” menu in the footprint editor. The .pretty folders are there in the stored folder where they should be, and there are .mod files inside of them (from when I created the new library). I went through the normal process of adding them to the global footprints library table with the wizard, and they show up there just fine, but they’re missing from the “Set Active Library” menu. I’ve tried searching using the filter too, they’re just not there.
I can post pictures or folder hierarchys if you need me to.
If you have .mod files inside .pretty folder this might not work - depending of selected plug-in and library table entries.
The .mod files are legacy libraries - one file per library. For each .mod you have to set one row in library table and set plug-in type to “Legacy”. The .pretty folders are new KiCad footprint libraries which should contain only .kicad_mod files. One .kicad_mod file per footprint. For each .pretty library you have to set one row in library table and set plug-in type to “KiCad”.
I feel a bit silly now. The missing libraries are there, it’s just that for some reason they weren’t showing up until I rebooted my PC and ran kicad again. Sorry for the trouble,
