Bug(fixed) - Schematic Editor : Autoplace fields does not work
Hi everyone,
Working on 6.0rc1, I stumbled upon the following behavior:
The clip shows me hitting the “O” Button to no avail.
The action should have moved the fields from the pull-up resistor on SCL to the left.
Selecting “Autoplace Fields” with the mouse doesn’t work either.
NB. I am working with the standard grid
here is the same situation under 5.1.12 - it works without any problems:
Eeschema — hmw01.sch _ — O__BAUMAN_HMW101_hmw01 2021-11-24 20-36-28
My KiCad version:
Application: KiCad Schematic Editor (64-bit)
Version: (6.0.0-rc1-120-ge56e61ffb5), release build
	wxWidgets 3.1.5
	libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19043), 64-bit edition, 64 bit, Little endian, wxMSW
	Date: Nov 22 2021 20:00:19
	wxWidgets: 3.1.5 (wchar_t,wx containers)
	Boost: 1.76.0
	OCC: 7.5.0
	Curl: 7.78.0-DEV
	ngspice: 35
	Compiler: Visual C++ 1929 without C++ ABI
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
Alexander aka @hwreverse
Jon fixed it a few hours ago…
(Cool diamond ring avatar.)
Tested with g08cb573e11 and can confirm it ! :blush: Kudos & Thank you!
PS: the diamond ring is one of a series of photos I’ve taken myself during the total solar eclipse of 2006-03-29 (I traveled to Turkey just for the photos.)
I’ve put 5 of them on my Google Drive (enjoy & share , just don’t sell) . Check out also the perl necklace, the corona (2006 was a year of low sun activity, so small corona)
https://drive.google.com/drive/folders/1Bo5y7K1KW0ZpUwHc-AzANI-Q7UbWeDM9?usp=sharing
Best Regards,
Alexander
That triple bead image is really nice!
I’ve done some solar sketches, but I’ve never done any photography. http://www.rokeby.ie/index.html?panel=observatory
