Broken packages Kicad-9.0 on ubuntu 22.04
I used sudo apt install kicad which gave the following output:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libocct-data-exchange-7.6 : Breaks: libocct-data-exchange-7.5 but 7.5.1+dfsg1-2ubuntu1 is to be installed
 libocct-foundation-7.6 : Breaks: libocct-foundation-7.5 but 7.5.1+dfsg1-2ubuntu1 is to be installed
 libocct-modeling-algorithms-7.6 : Breaks: libocct-modeling-algorithms-7.5 but 7.5.1+dfsg1-2ubuntu1 is to be installed
 libocct-modeling-data-7.6 : Breaks: libocct-modeling-data-7.5 but 7.5.1+dfsg1-2ubuntu1 is to be installed
 libocct-ocaf-7.6 : Breaks: libocct-ocaf-7.5 but 7.5.1+dfsg1-2ubuntu1 is to be installed
 libocct-visualization-7.6 : Breaks: libocct-visualization-7.5 but 7.5.1+dfsg1-2ubuntu1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I followed the question (and the question inside posted by @retiredfeline ) from here: https://forum.kicad.info/t/broken-packages-on-ubuntu/48307
I tried to remove, install, update and upgrade the broken pakages but it did not help.
Any good reason not to be running the current and already one year old LTS 24.04?
older LTS receive support to run the original applications, but updates can be broken.
KiCad 7.0 had the same problem, KiCad 8.0 was without the Problem. I tried to patch the *.deb-file - See here [Problem] Installing FreeCAD 21.1 removes KiCAD 7.0. on Ubuntu 22.04 - Reinstall of KiCAD is not possible. · Issue #12153 · FreeCAD/FreeCAD · GitHub but pcbnew can’t start…
So I reset to KiCad 8.0…
