I just got my second KiCAD-designed PCB. I am happy with most of it, except for the solder pad ring of the 3339 Bourns potentiometer (vertical), which is way too small. The footprint is defined within KiCAD. It makes hand soldering quite difficult. Can I send you the updated footprint so that you correct it in a future release?
Also, I have designed a footprint for https://assets.lairdtech.com/home/brandworld/files/28C0236-0JW-10.pdf
May I send it to you so that you also include it in the next release?
Thanks for the support!
