Am thinking I’m probably the only person trying this. The Asahi Fedora aarch64 build is crashing on launch. Is anyone else seeing this? Any tips other than strace?
Application: KiCad aarch64 on aarch64
Version: 7.0.8-1.fc38, release build
wxWidgets 3.2.2
FreeType 2.13.0
HarfBuzz 7.1.0
FontConfig 2.14.2
libcurl/8.0.1 OpenSSL/3.0.9 zlib/1.2.13 brotli/1.0.9 libidn2/2.3.4 libpsl/0.21.2 (+libidn2/2.3.4) libssh/0.10.5/openssl/zlib nghttp2/1.52.0
Platform: Fedora Linux Asahi Remix 38 (Thirty Eight), 64 bit, Little endian, wxGTK, KDE, wayland
Date: Sep 29 2023 00:00:00
wxWidgets: 3.2.2 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.78.0
OCC: 7.6.3
Curl: 8.0.1
ngspice: 41
Compiler: GCC 13.2.1 with C++ ABI 1018
KICAD_SPICE=ON
strace eeschema
openat(AT_FDCWD, "/lib64/librsvg-2.so.2", O_RDONLY|O_CLOEXEC) = 17
read(17, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
newfstatat(17, "", {st_mode=S_IFREG|0755, st_size=4368680, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 4392160, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff3818c000
mmap(0xffff38190000, 4326624, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 17, 0) = 0xffff38190000
munmap(0xffff3818c000, 16384) = 0
munmap(0xffff385b4000, 34016) = 0
mprotect(0xffff3821c000, 3276800, PROT_NONE) = 0
mmap(0xffff38220000, 2031616, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 17, 0x90000) = 0xffff38220000
mmap(0xffff38410000, 1163264, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 17, 0x280000) = 0xffff38410000
mmap(0xffff3853c000, 491520, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 17, 0x39c000) = 0xffff3853c000
close(17) = 0
mprotect(0xffff3853c000, 475136, PROT_READ) = 0
mprotect(0xffff385fc000, 16384, PROT_READ) = 0
munmap(0xffff40004000, 111779) = 0
futex(0xffff65f60e98, FUTEX_WAKE_PRIVATE, 2147483647) = 0
getrandom("\x3f\x74\xfb\xef\x73\x9a\xc3\xc8\xe8\x58\xd7\x56\x5c\xb5\xad\xf6", 16, GRND_INSECURE) = 16
brk(0xaaab90094000) = 0xaaab90094000
close(16) = 0
mmap(NULL, 1064960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff3808c000
--- SIGILL {si_signo=SIGILL, si_code=ILL_ILLOPC, si_addr=0xffff51dec444} ---
+++ killed by SIGILL (core dumped) +++
Illegal instruction (core dumped)
[tom@macbook-air-m2 hardware]$
strace pcbnew
mmap(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff3c0a4000
getcwd("/home/tom/git/TomKeddie/tom-amd-2023-winterlude/hardware", 1024) = 57
newfstatat(AT_FDCWD, "/home/tom/git/TomKeddie/tom-amd-2023-winterlude/hardware", {st_mode=S_IFDIR|0755, st_size=2712, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib64/python3.11", {st_mode=S_IFDIR|0755, st_size=4014, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib64/python3.11/lib-dynload", {st_mode=S_IFDIR|0755, st_size=5624, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib64/python3.11/site-packages", {st_mode=S_IFDIR|0755, st_size=2840, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/python3.11/site-packages", {st_mode=S_IFDIR|0755, st_size=4970, ...}, 0) = 0
newfstatat(AT_FDCWD, "/home/tom/.config/kicad/7.0/PcbNew.hotkeys", 0xffffe9dbaf78, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/home/tom/.config/kicad/7.0/user.hotkeys", 0xffffe9dbb068, 0) = -1 ENOENT (No such file or directory)
brk(0xaaab808e8000) = 0xaaab808e8000
brk(0xaaab8090c000) = 0xaaab8090c000
brk(0xaaab80a2c000) = 0xaaab80a2c000
--- SIGILL {si_signo=SIGILL, si_code=ILL_ILLOPC, si_addr=0xffff433deaf4} ---
