I’m trying to run KiBom from the command line with no GUI interaction at all. I noticed that in projects where I haven’t run the BOM from the GUI, there’s no xml netlist (at least on windows with Kicad 5.1.4).
Is there a way to generate that XML netlist (ideally from the command line) so I can run KiBom from the command line? The alternative I see is runing the BoM at least once from the GUI, but that’s prone to errors as it would be very easy to forget to update the XML if something changes in the schematic, and you would be generating an outdated BoM
