Hi I’m trying to generate a bom file with this script that worked fine to me in previous releases of kicad. But after update to 5.0 it is broken.
In build settings there is KICAD_SCRIPTING_WXPYTHON=OFF
That is the reason why i can’t use the script? Or there is something else?
Run command:
python2.7 "/usr/lib/kicad/plugins/bom_csv_grouped_by_value_farnell.py" "/home/g/Drive/a/k/PCB/v2/k_v2.xml" "/home/g/Drive/a/k/PCB/v2/k_v2.CSV"
Command error. Return code 1
Error messages:
Traceback (most recent call last):
File "/usr/lib/kicad/plugins/bom_csv_grouped_by_value_farnell.py", line 19, in <module>
import kicad_netlist_reader
ImportError: No module named kicad_netlist_reader
Kicad Version
Application: kicad
Version: 5.0.0-rc2-unknown-0e3be57~65~ubuntu16.04.1, release build
wxWidgets 3.0.2
libcurl/7.47.0 OpenSSL/1.0.2g zlib/1.2.8 libidn/1.32 librtmp/2.3
Platform: Linux 4.13.0-45-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.58.0
Curl: 7.47.0
Compiler: GCC 5.4.0 with C++ ABI 1009
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
