With KiCAD 5.99 nightly, I only see two BOM scripts bom_csv_grouped_by_value bom_csv_grouped_by_value_with_fp
Both are failing when trying to run them. I can copy the command into the terminal and once I change python to python3 they will run just fine.
Is this a problem on my side or should I log an issue on gitlab?
That would be a workaround and certainly one may argue that that’s an issue of ubuntu for not doing that by default.
On the other hand, I do think KiCAD should just work in any case.
I filed an issue in the gitlab:
