BOM includes 4 entries for each component
Hi everyone. When I generate a BOM from Schematic Editor each component ends up in the BOM with at least 4 entries. Doesn’t matter which of the three built in BOM generator scripts I choose.
It’s not a complex circuit, so it doesn’t take much time to clean up the file. Still I’d like to prevent having to do that. What am I doing wrong?
I’m still using v7.09 for Mac:
Application: KiCad arm64 on arm64
Version: 7.0.9, release build
	wxWidgets 3.2.3
	FreeType 2.13.0
	HarfBuzz 7.3.0
	FontConfig 2.14.2
	libcurl/8.4.0 (SecureTransport) LibreSSL/3.3.6 zlib/1.2.11 nghttp2/1.51.0
Platform: macOS Ventura Version 13.6.4 (Build 22G513), 64 bit, Little endian, wxMac
	Date: Nov  7 2023 18:28:14
	wxWidgets: 3.2.3 (wchar_t,wx containers)
	Boost: 1.82.0
	OCC: 7.7.0
	Curl: 7.77.0
	ngspice: 41
	Compiler: Clang 13.0.0 with C++ ABI 1002
	KICAD_SPICE=ON
To generate BOM I am using bom_csv_grouped_by_value_with_fp.
I am still in KiCad V7.
I have never had a problem with my elements being listed more then once in the BOM.
As your circuit is not complex then I think that the only possible way anyone can help to find the problem source is to post the project (PCB not needed) to be checked by others.
