hi i am trying to generate a BOM but am struggling, im running ubuntu, i have been through replacing all my spaces with an underscore as recommended by some other posts i have seen (i was surprised everything still worked after being renamed so there may have been an issue there but it all seems fine).
when i run bom2grouped i get this error code
Run command:
xsltproc -o “/home/mike/Documents/Kicad/Project_Atlas_THT/Project_Atlas” “/usr/share/kicad/plugins/bom2grouped_csv.xsl” “/home/mike/Documents/Kicad/Project_Atlas_THT/Project_Atlas.xml”
Command error. Return code 11
Error messages:
I/O error : Is a directory
i ran it as sudo in terminal with the same result, does any one know whats causing this?
That is the file path now, i just changed the folder names.
From terminal:
~/Documents/Kicad/Project_Atlas_THT$ pwd
I’m not sure if this will fix it, but try changing “/home/mike/Documents/Kicad/Project_Atlas_THT/Project_Atlas” to “/home/mike/Documents/Kicad/Project_Atlas_THT/Project_Atlas.csv”
Note the .csv at the end.
Kicad was recently patched to automatically add the output file extension – will be in 5.1.10 and 6.0. I think that’s later than your version but I can’t tell from your commit hash.
