Is it any automation way to create separate bill for each of hierarchical sheet in current version( 4.0.7).
Before, in old stable version I didit like this:
1 Open eeschema, one of the hierarchical sheets, and save it in different folder then project is, use Save Current Sheet As. It will save current sheet with current annotation.
2 Repeat item 1 for all sheets in project.
3 Open each sheet.sch in Kicad and use BOM button
4 In windowof generation bill choose some options and formats ( as usually I need sorts the parts by value and component reference and save it as two types of bills of materials )
5 Then repeat item 5 for each sheet.
In 4.0.7 plugin for generation bill of materials little bit change, there is no too much options now. I need to get true CSV if possible after the fashion of the older versions. That allowed the choice of grouping by common attributes or by individual components
