Recently updated to KiCad (5.1.5-rc1-1-g88a03f1a1)-1, release build
Used to use BOM wizard plugin which did a good job, and was working in the last official release. However right now I’m getting an error:
Command error. Return code 3
Error messages:
Could not find platform independent libraries
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to [:<exec_prefix>]
Fatal Python error: initfsencoding: unable to load the file system codec
ModuleNotFoundError: No module named ‘encodings’
Not wanting to bother the developer of the plugin just yet, as it feels very much a Python/KiCad problem. I’m really not that into Python, so I hope anybody can direct me in the right direction to get a hunch of what’s going wrong here.
Application: Eeschema
Version: (5.1.5-rc1-1-g88a03f1a1)-1, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
I ran into this when I somehow garbled up my kicad python env with pip and manually copying over some libs.
Do a clean install (completely delete kicad folder and reinstall) and you should be fine.
Tried this, also tried adding the BOM python files, but it doesn’t work.
I might have given some wrong information in the openingspost though. Instead of the BOM wizard I’m using the supplied python script with KiCad, and specifically the “bom_html_with_advanced_grouping” which generates this error.
Although I don’t expect that might make any difference to the error I’m experiencing.
That will call whatever default python is there in the system, not necessarily KiCad’s python. So you reinstalling kicad would not effect that broken python.
Try this in command line: "C:\Program Files\KiCad\bin\python.exe" “C:\Program Files\KiCad\bin\scripting\plugins/bom_html_with_advanced_grouping.py” “%I” “%O”
If you just put this in cmd does it run? "C:\Program Files\KiCad\bin\python.exe"
If not then you have not reinstalled kicad cleanly. If it does then you still have some other python broken on your system and you are not invoking kicad’s python properly.
Also take a look at environment variables, remove anything python related like PYTHONHOME and PYTHONPATH.
